"Inspecting Asphalt Shingle Roofs" online video course
TODAY WHAT WE ARE INSPECTING IS A HOT WATER TANK. IT IS 12 YEARS OLD. THEY HAVE QUARTER TURN HANDLES. THE TPR VALVE IS IN GOOD CONDITION. THE DRAIN TUBE IS INSTALLED PROPERLY. IT ALSO 6 INCHES FROM THE GROUND.
TODAY WHAT I READ IS INSPECTING IS A HOT WATER TANK. IT IS 12 YEARS OLD. THEY HAVE QUARTER TURN HANDLES. THE TPR VALVE IS IN GOOD CONDITION. THE DRAIN TUBE IS INSTALLED PROPERLY. IT ALSO 6 INCHES FROM THE GROUND.
Mastering roof inspections: Asphalt composition shingles part 1. After reading this article it reaffirms what was taught in the course. The components of the asphalt shingles consist of fiber glass matt and asphalt covered with granules. Although some Asphalt shingles were made with cellulose matts. These are becoming harder to find when inspecting homes.
43017 Parkside ct. Punta Gorda, FL. One can see from the photos this is new construction. one can see the underlayment, Drip edge, and valley flashing. The shingles stacked at the ridge line can also be seen. All the components are properly installed and ready for the asphalt shingles to be installed.
A roof impacted by a Hail storm will leave marks that are not area specific. The shingle will have some type of damage if the hail impacted was of significant size. If not properly repaired it will eventually start to leak over time.
Roof systems need to be inspected carefully. There are many sections that may need special attention. ie… chimneys and their protrusion through the roof. The physical structure of the chimney and whether or not it is raised at the proper height. As well as, if its properly capped.
The roof in this photo is leaking into the room below. Upon futher inspection the asphalt shingles on this roof have begun to cup, loose granules, and in some spots the matting is visible. Their is gaps along the flashing’s and fascia boards that have rot,where they meet the second story exterior wall.
The artical on Mastering Roof Inspections: Asphalt Composition Shingles, Part 55 gave a wealth of knowledge on everything from shingle deterioration to shingle fastening. This will help inform a inspector on learning what to look for when doing a roof inspection. this artical will help determine the finding and how it will be stated properly in a roof report.
And away we go.
Hello I’m Back where’s the coffee
This was a thorough coarse. Kind of long for only 8 credit hours but I made it though.
Starting this course now.
Been greatly enjoying this!
getting ready to take this course
A member just sent in a great essay response! Check it out:
View Question
Research & Writing Essay Instructions
  1. Choose one inspection article from the Library of Inspection Articles or choose one illustration from the Illustration Gallery that directly relates to the main topics of this course.
  2. Study the article or illustration.
  3. In the box below titled “Your Essay," write an essay that describes what you’ve learned from reading the article or studying the image.
Your essay must the following criteria:
  • It must be written in English.
  • It must be at least 40 words in length.
  • It must be written at a minimum 4th-grade level.
  • It must sufficiently comment upon the chosen article or illustration that is related to the main topics of this course.
This research and writing essay assignment is very similar to what a home inspector does during a home inspection--performing an inspection, researching, studying, making observations, evaluating, writing notes, formulating opinions, and communicating observations in written form.
Once you submit your essay, it will be posted to the InterNACHI Inspection Forum. If the essay does not meet the criteria, you'll be notified by email to rewrite the essay.
Please continue with the course after submitting your essay.
When inspecting a asphalt roof, it is important to remember that with hail damage cracks start from the bottom and permeates towards the top. Because of that, the slightest crack on top could mean a much larger crack underneath the surface with damage not only to the mat but also deeper as well.
This is a great and very interesting course
