Inspection Advice
This is what my inspection states about my attic roof. Is it as serious as it sounds? I even asked AI and it said my roof would collaspe. Any words of wisdom would be appreciated. Thank you.
Rafters are improperly spliced at the corners of the attic. Splices in rafters generally require vertical support under the splice. If not supported, splices using gusset plates should be designed by a professional structural engineer, with evidence provided that the splices were performed properly. Recommend an evaluation/correction by a qualified licensed general contractor.
(2) Note: It is recommended that a vertical support be installed where several rafters tie together to prevent sagging from support of just nailing for main roof
What did the qualified licensed general contractor say?
I have someone going out this weekend to look at it. I found this site and thought I could get some advice while waiting. Sometimes it sounds worse than it is. Thank you.
I’m not trying to be rude. But it is comparable to me asking you how many fingers that I am holding up. There is just too much information missing for anyone to answer correctly.
That is an odd statement in the middle of a defect narrative. Why was vertical support abandoned for engineered gussets plates?
Is there any sign of settlement or failure? Sagging?
I understand. It was worth a try. I will be patient and wait for the contractor to have a look. Thank you all though.
Not that I know of. The house was built in 1980. I would have thought if any issues they may have happened by now. But obviously I have no clue.
Were there any pictures in the report you can upload here?
Not very clear.
I take back what I said earlier.
My opinion is different than the inspector that wrote this.
What are you thinking Jeff?
There are many questions from this. Starting with these.
  • You state “my inspection”. Is this you performing an inspection? Are you an Inspector? Or did an Inspector perform an inspection and provide these images to you?
  • Are you the recent buyer of this home or are you in the process of buying it?
  • If you are not the recent buyer are you the owner and how long have you owned the home?
  • When did AI tell you that specifically your roof would collapse? There is nothing in this post stating that.
  • What was AI’s specific statement that said your roof would collapse?
Who wrote this? Was this you, the Inspector, or AI?
An inspector wrote this for a property I am buying. I put the section of the narrative about the roof in AI and asked AI to put it into terms I could understand. AI said it was serious structural issues which risked roof collapse.
One of reasons I don’t trust or use AI.
Hi Tracy, where are you (the home pictured) located?
These are called “hip” rafters. Unless there are other problems not visible in your photos, it looks like a typical installation from here.
Here’s a graphic:
Here’s an article about Hip/valley framing.
