The pin type can also be used to fend off would be assailants if you pretend its a stun gun
I occassionally put my moisture meter on clients arm to see if they still have blood coursing through their veins! They usually have a good laugh.
Just ordered the [FONT=Times New Roman]**Model CT808: *****Range 0% - 100% Digital Microprocessor ***and the total cost including: calibration plate, grab & steal tax and shipping. is $379.98. [/FONT]
No Prov. steal tax in AB.
From
Mould growth requires moisture to grow. If there is no moisture then the mould is not present and if it is it is dormant. If the test is positive then start looking for the water source. Seepage in basements, Pipes leaking. Roof leaking, Window condensation, Condensation in attic, etc. It’s the Etc that can bite you. :shock:
I’ve found mould growing on window glass because the occupant has thick curtains that he never opened and high humidity.
The moisture test is a warning to look until you find the source.
</IMG>
For those who are not members of COSCO I just got my new Home Depot flyer and they now have the Telescopic ladder in Canada also $259. 00 .
Not for me I like my little giant up and down over 10,000 times still works great . Added Information the Choice lubrication for aluminum ladders is End dust ( Yes the stuff mother uses for furniture ) Little Giant told me this 5 years ago and it does a good job.
Roy Cooke … Royshomeinspection.com
Like I said before, when all the work is complete, I will be able to get the ladders for less than $200.
Keep us informed, under $200.00 is good:eek:
Sorry I wasn’t able to respond due to login problems.
Thank you all very much for the great information. I was flabbergasted to see over 40 responses!
Thanks again!
Little Giant ladder on sale at Home Hardware this week
Great price if any one is thinking this is the one I recommend . Roy sr
Thanks Jeannot
http://homehardware.flyerservices.com/flyer/noncached_pages/HHDW_PU008E_120_eng_ProductDetail.asp?SID=454931875&Ref=HHDW_PU008E_120_eng_PG0019.asp&C=&T=&S={7430831F-C0A5-48DE-9FAA-BBAFF31790A3}&CC=0&Region_ID=020556e9-4121-4327-a68e-b5b00e4e3824
LADDER, LTTLE GIANTModel:10102 17FTHH Item Number: 5436762- 4 rungs (picture not exact)
- Four to five times more durable than the
typical ladders - Made of heavy-wall 6005-T5 aluminum
- Work load capacity of 300lbs, it has been
tested four times that amount without
structural failure - Adjustable nature allows it to be safely used
on stairs, ramps, curbs, docks, or other
uneven surfaces - Types of configuration: scaffolding, A-frame,
stair step, lean-to, extension
SPECIFICATIONS: - Extension height: 9’ - 15’ (2.74m - 4.57m)
- Stepladder height: 4’ - 7’ (1.22 m - 2.13 m)
- Scaffolding height: 4’ (1.22 m)
- Storage height: 4’7" (1.40 m)
- Weight: 35 lbs (15.88 kilo)
- Warranty: 5 years Page 19 Price: $329.97
Roy, this seems like a great deal. However, this one only extends to 15’ which doesn’t seem to be anywhere near what would be required for a 2 story roof. Would probably need one that extends at least to 19’ would you agree?
I have been using this size for 7 years If it will not get me there then I do not go .
I have a 25 power scope on a tripod that I can use if needed.
Any longer is not handy for getting up in the attic.
I know of many HIs who use this size and are very successfull .
Roy sr.
Sorry mine is a 10202
Tyrone,
Any luck yet getting 12.5" Telesteps here in Canada for about $200?
-James Walker
Andy, you may have to go to an industrial products supplier like Wolseley, Aklands Granger, Tenequip or Fastenal (to name a few). Another option is to shop through E-bay but if you do that, remember, “buyer beware”. Good luck and cheers to quality inspections.
I bought a ladder a couple of weeks ago at Canadian Tire, it folds up to about 5’ 6", and extends to 19’. It is made by Lite Products Ltd. and I paid $300 on sale.
