Mr. Martin,
First let me say…and I am sure others may not agree but to have K&T in a home that is only 40 years old lends me to think it may have been remodeled 40 years ago but may be older…but again that might be just me thinking this…anyway…
When dealing with K & T you have to consider many things as todays standards as far as NFPA see’s it would not require changing it but it sounds like many things associated with it are being changed in the structure which causes a problem…you analysis of K & T is valid to a point but the bad thing about K & T is when it starts to be altered past is original ( common netural ) approach by home owners to meet their current needs of today…ie: continuous and linear v. non-linear loads the problems become compounded on the shared neutral structure of K & T.
As you know insurance companies will march to the beat of their own drum as will their UWer’s who back the policy so they can change or add stipulations as they deem fit…Are you going to have problems when you see…well it depends entirly on the following-
1.) Are the upgrades made compliant to safety standards…irrespective to NEC standards…Safety is the foundation of the NEC via NFPA.
2.) Can the home be insured on a NEW policy versus a ongoing one that may have grandfathered the existing coverage…the prospective buyer will have to check that out…if bought right out with no mortgage quite possibly their choice if they want to buy without insurance…then again a carrier may have no problem with it…really depends on the inspection and review.
Their is a proper way to transition from K & T to modern day wiring but I just happen to be one of those electricians who believe you should just not splice in willy nilly and consider it upgrading anything…it has to upgrade to the distribution point to be a true fix…
Taking exposed wires lets say in an attic that are K & T and placing them in a box…provided the proper fitting and insulators are used is not an upgrade…only a enhancement and it really does not reduce the shared properties of the system wiring itself.
The concept of K & T being safer I guess came from the fact it has no ground…thus giving no equal grounding reference point…but in your case that is no longer the case…so it really should be evaluated by an electrical contractor that KNOWS knob …one who can review the changes being made…much like a structural eng. will review truss alterations and suggestions on compliance approvals.
The dangers of K & T are not always the same as in modern wiring…but some are like overloading the shared netural, fuses that can be altered wrongly and mostly unprotected wires that can be exposed to damage…making sure they stay min. 3" apart from each other and 1" from the surface.
I just dont think an inspector can tell you how the sale will go but we all will write it up as K & T and suggest it being reviewed by a licensed electrical contractor for obvious reasons…does that mean it has to be changed…we no unless other remodeling has been done and it is perfectly allowed to splice to other methods of wiring but must be inside a box and so on…
Now…with all that said is K & T allowed today…well in new constructon obviously not…but it is allowed for adding onto existing dwellings that use K & T as well by special permission from the AHJ…good luck on that ever happening…
Conclussion- The best thing to do is see if the insurance company that will carry the insurance to the new buyer will cover a K & T installation…or in a situation where the buyer pays cash…they obviously will need to know it is K & T and live or DIE with their choices…
Hope this helps any…others may have different opinions on it but again all HI’s will call this out and it will freely be in every report submitted as sub-par wiring and not to the safety standards of today not just simply because it is K & T…but because of what the HI also CANT see…
