Originally Posted By: bpartlow This post was automatically imported from our archived forum.
I cannot remember which manufacturer it was, but there is one that instructs you to install csst in the cabinet because of the configuration of the equipment on one particular model. I will try to look it up again and get back with you on the brand and model
is for interior use only and may pass through walls and/or floors.
Appliance connectors may not pass through walls and/or floors. Appliance connectors must be installed at the appliance in accordance with the appliance manufacturer.
Appliance connectors are usually short lengths (< 4' ) with an inside dimension (ID) of 1/4" typically.
CSST, when installed as gas piping, is long lengths typically with an ID of 3/8" or greater. Steel piping is used for the transition from the gas line to the appliance connector.
Will, UPC 1212.2 deals with gas connectors or appliance connectors.
I was forced to make the call today when I found this in a condo built in 2003.
It's difficult to tell from the plaster coating, but these are all CSST lines passing up through the floor from the garage.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: mlong This post was automatically imported from our archived forum.
Jeff,
If CSST is only for interior use, what is to be used on the exterior? steel? copper?
I'm going to have to look into this further. In my local area, I've seen many applications where the CSST was run from the LP tank outside directly through the wall and into an appliance and/or through a masonry fireplace right into the fireplace for a gas log or gas insert.
Originally Posted By: jhugenroth This post was automatically imported from our archived forum.
I know local codes prevail, and the manufacturer may allow it. My code check book states that it may be installed INSIDE access door of a wall furnace. I see it all the time, and it is allowed in all cities and counties in my area.
I assume you’re referring to the UPC or UMC as you are in CA.
I did research this and went as far as calling the Building and Safety Department. If you can provide me with the code section and reference, I would greatly appreciate it.
-- Jeff Pope
(661) 212-0738
Originally Posted By: whandley This post was automatically imported from our archived forum.
Hi Joe; Maybe were talking about different issues. I also find flex in
use at the interior service area of wall furnaces, but the run into the compartment and or through the floor to the unit is rigid pipe. The verbiage I’ve seen in the IRC, UPC, UMC and or Code Check only
addresses the issue of flexible gas connectors running through an appliance “WALL” as being an unsafe condition.
Will,
I was just commenting on what I saw in the picture in Heath John’s post that started the thread. I didn’t see the flex going through a cabinet anywhere in the pic.
