Howdy,
I recently had James Hardie horizontal lap siding (HardiePlank) installed on my home in the north Austin, TX area and I’m looking for a qualified inspector to perform a thorough post-installation review.
Specifically, I’d like someone experienced with James Hardie products who can check the installation against the manufacturer’s guidelines (clearances, flashing at butt joints, proper overlaps, fastening, WRB integration, etc.) to help ensure warranty compliance and long-term performance.
If you’re a CMI or have significant experience inspecting fiber cement/Hardie siding installs, please let me know:
• Your availability in the next couple of weeks
• Rough cost for a focused exterior siding inspection
• Any relevant background or examples of similar Hardie inspections you’ve done
I can provide the specific installation instructions for my Hardie Zone and access to the property. Photos of the work can be shared in advance if helpful.
Thanks in advance — I appreciate any recommendations
Edit: The home is a two-story 1,900 sq ft house. The exterior features 16 squares (1,600 sq ft) of 1x8 James Hardie horizontal lap siding. The back of the house is fully sided, the sides are approximately 50/50 siding and stone, and the front is partially sided on the second story along with the chimney area. includes James hardie soffit and fascia, two front gables, and trim on all windows and doors where the siding meets them.I’d like the inspection to cover all of these areas—including the siding, soffit, fascia, gables, window trim, and flashing—to ensure everything meets James Hardie manufacturer guidelines and best practices. Also, Installed direct-to-WRB-over-OSB.
