Landing or step at garage
Originally Posted By: dbroad
I am looking for the code and the code requierments for the size the landing or step when entering the garage from the house. I am in riverside county, Ca.
I believe it has to be larger then the door swing so you can be standing on it and open the door without stepping down and thewn back up.
Originally Posted By: jpope
Min landing size is 36" deep UBC 1003.3.3.5
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Jeff … is the CA code the same as the IRC (R311.4) where a garage exit door can have up to 2 risers without a landing, as long as the door does not swing outward over the lower garage floor or single step?
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: lewens
Does not the IRC say the garage door has to swing into the garage?
Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
roconnor wrote:
Jeff ... is the CA code the same as the IRC (R311.4) where a garage exit door can have up to 2 risers without a landing, as long as the door does not swing outward over the lower garage floor or single step?
Nope. No such requirement by UBC.
IRC 311.5.4 mirrors UBC 1003.3.3.5 and 1003.3.1.6 with regards to landings and door swing respectively.
Jeff Pope
(661) 212-0738
