You are playing OVER analysis…not sure if you are doing so to funny or just dont understand.
The video clearly says that OF the items looking for in determining the service the meter itself is the one that should be TOSSED if you find the other determining factors.
Are you telling me as a HI you would PUT the size of the meter enclosure as the main sizing factor on your report…I sure HOPE NOT. While 100% of the time we can’t actually SEE the rating of the enclosure we have to ASSUME using sizing and varibles that leave us GUESSING…some 100A square cans are actually 125A Cans…and some round 60A cans can indeed in some areas of the country be approved by the POCO for 100A cans…the image I show above was a round one which the POCO said was approved for 100A…so because it is round and I can’t actually SEE the listing in the enclosure because it is sealed…and because it had a freakin CL200 in it…it appears to be a 60A can with a 200A meter in it on a 100A panel…so I freakin THROW that one out…and use the factors I can see…Conductor Size, Enclosure Rating if possible, Main OCPD size and in this case the Mast conductors size…to determine it was indeed a 100A panel.
We have shown MANY times that CL200 means nothing really…and I have seen them in smaller cans…you have to use judgement otherwise I would have to do a freaking video 10 minutes long to explain all the possible ways…
You use the meter enclosure as a helping factor…and it MAY be a helpful determining factor…but we are saying it MAY be used…or it may not be used…depends on each unique situation and IF you had to throw ONE factor out…the meter enclosure or meter would be that one…because we have seen 200A services but the POCO has approved a smaller meter can…and visa versa…so it MAY way on your judgement BUT it is the less concerning issue…
Now if you are seeing an unauthorized service change…where they did not resize the service drop conductors or mast conductors then you know something MAY be up…but thats on an individual basis only.
