What is your thoughts on a light switch located on wall that shares the same wall cavity as the shower plumbing. I know current standards call out light switches should not be within 3 feet of the bath or shower. In this case the switch is but in an indirect way. I know indirect or not the switch still is too close.
Here is the narrative I wrote, what are your thoughts. Is this an issue or would you just have moved on.
“Master bathroom, poor placement of bathroom light switch. Light switch shares same wall cavity as the shower’s water supply pipes. I recommend relocating light switch or installing GFCI protection on the light switch circuit to help prevent potential of a shock or electrical damage if a plumbing leak should occur inside the wall cavity.”
Are we talking same wall cavity with switch on the other side of the wall? Wouldn’t the pipes from the shower in the wall cavity be about three feet from the switch box and wiring that is running inside that wall.
