Light switch within 3 feet of shower
Originally Posted By: jgallant
I’m reviewing my copy of the “1 & 2 Family Dwelling Electrical Systems” now, but can anyone tell me what the rules are concerning the proximity of wall mounted light switches to showers and tubs. I thought a rule (NEC?) existed prohibiting wall mounted (fan, heater or light) switches from existing within 3 feet of a tub or shower enclosure. This to discourage wet people from operating 110v switches.
-Jim Gallant
Owner, All Point Home Inspections - Poulsbo, WA www.allpointinspections.com
Co-founder, ReportHost (Web-based report writing service) www.reporthost.com
Originally Posted By: gbeaumont
Hi Jim,
I know you are basically correct, I am not near my NEC tonight but If I remember correctly the distance from tub or shower to switch is actually 5 feet.
regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
No distance. Just not inside the shower “area”.
Mike P.
Originally Posted By: dvalley
The NEC doesn?t specify a distance, but all switches that control bathroom lighting should be installed at the entrance to the bathroom. Why would someone need a switch near the shower anyways? DUH
There's only one switch that can be near water and that is the jacuzzi on-off switch. That particular switch is protected against water hazards.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: Bob Badger
I have had to place them near the tub when the bathrooms where small.
Did not want to, but that was what the plans showed. ![icon_sad.gif](upload://nMBtKsE7kuDHGvTX96IWpBt1rTb.gif)
Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
It is still considered better practice to place all switches and receptacles at least 3’ away from a tub or shower, and thats probably what you are thinking about … icon_idea.gif
Gerry ... I believe you are thinking about the 5' clearance rule for switches and outlets related to outdoor pools and spas (IRC E4103.2) ...
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
Originally Posted By: jpeck
Because, DUH, you may have a tub on the left of the door, the lavatory straight ahead, and the water closet to the right. You walk in, the switch is near the shower - but not IN the shower or tub area. All depends on which way the door opens. The switch COULD have been on the right if the door opened the other way.
Jerry Peck
South Florida
David Valley
MAB Member
The bathroom in question for me had two sinks with the shower adjacent to one of the sinks. A switch was installed for each of two light fixtures over the sinks (his n’ hers). One of the switches was right next to the edge of the shower enclosure. It wasn’t IN the shower enclosure, but inches from the edge. New construction too.
I'm not sensing a consensus on this.
-Jim Gallant
Code does not say not to put it there.
Jerry Peck
South Florida
Originally Posted By: ekartal
The only thing I could find was that a receptacle is required within 3’ of basin. IRC [381.6].
Erol Kartal
ProInspect
I agree, the NEC allows the switch right next to the shower, the graphic above is correct.
Bob (AKA iwire)
Jim,
Slide the curtain or shower door closed, if the light switch is inside this wet area, it's a "red flag".
Pretty simple, no tape measure required.![](upload://2ubpHK3yn8KBPErH5FUvdHPsrJn.gif)
David Valley
MAB Member
Dave
I love your Emoticons.
I have a four gang just outside of my master bath shower, which I wired, and see no problem with this.
I doubt if my wife will reach from the shower to the switch to turn off the light above her.
That said, this circuit IS GFCI protected.
Mike P.
Robert O’Connor, PE
Eagle Engineering ?
Robert
Are giving me another 90.4 loophole? ![icon_smile.gif](upload://b6iczyK1ETUUqRUc4PAkX83GF2O.gif)
Mike P.
