Originally Posted By: dandersen This post was automatically imported from our archived forum.
Just for info, the HVAC contractor can just fix the bend with a flairing block.
This repair must be made by a certified contractor because of the chance of refrigerant discharge.
The kink in the line has the same effect as the metering device at the indoor coil. The pressure drop at the kink may cause the liquid refrigerant to flash and start the refrigeration process outside the evap coil. Water damage could occur because the liquid line is not insulated.
Originally Posted By: rwand This post was automatically imported from our archived forum.
…or… “service the A/C line prior to closing of Title.” That way the vendor would have to deal with it. Why should the purchaer get stuck for a repair that the vendors installer caused?
Raymond Wand
Alton, ON
-- The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
