Just finished my logo design. Would like your thoughts. I had my sister in law design it as she is a graphic designer. So no need for the InterNACHI marketing material being required I believe, but would you still put it on there or as long as the website and business cards etc states it with the certified badges and such would that be fine?
Attached is my logo/branding board for different usages and locations aka web, print, clothing
I like the one at bottom right, one to left, with roof top.
If you don’t already have your business name finalized you may want to add home or property in front of inspection, and maybe use inspections, with an S at the end. Just a thought.
The only negative I’ll mention is that while the intricate design and thin lines of the house and mountains are beautiful in a large size, it doesn’t play well as a logo on a tiny smartphone screen. The current trend in logo design is to make simpler and bolder designs to account for the fact that most people will be seeing your logo shrunk down in the corner of a tiny smartphone screen.
I think you got it. Truck logos and such, NACHI logo may clutter the design, I would probably move my credentials away from my logo and phone number to insure clarity, quick read and branding.
Thank you - yes I figure 4 counties where I live is a few hours drive depending on where. I commute 140 miles to my current fire job through some crappy snowy mountain passes - so I’ll be willing to drive!
Don’t busy it up too much. Simpler is often better. My first cards had way too much packed in and were difficult to read. Yours above look pretty good but if you want to add more you can always put it on the back. If you do use the back, that would be a good place for a profile pic. People like to see who they are dealing with.
