Originally Posted By: jkormos
Thanks John
Originally Posted By: Jay Moge
Originally Posted By: rcooke
Jay Moge wrote: |
the major problem that should be called out is the vertical flashing. it essential re-introduces the very problem the cricket is supposed to solve. when water runs between the ridges of the roof it is allowed to pool against that flashing and hold there until it dries, leaving all the litter. without the flashing water and debris can flow over and off the sides of the cricket and down to the drainage system. the tar also slows down this process. I'd write it in the report, mention that it could shorten the life of the seam and suggest they have it fixed at there nearest convenience. no huge hurry though. |
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: dandersen
Quote: |
This is a little neater but still has roof compound in the joint. |
Quote: |
If it's not leaking why would you call it out? |
Quote: |
Recommend further evaluation and proper installation by a qualified Roofing contractor. |
Roy Cooke Sr.
Quote: |
Yes I do tell them it is not a case of will it leak but when will it leak. |
Quote: |
Same thing with bald tires you know there is going to be a flat . |
dandersen wrote: | ||||
What model crystal ball is it your using?
But it's not flat today! Just tell them the tire on the roof is bald but not flat. . |
Roy Cooke Sr.
Originally Posted By: mcyr
Originally Posted By: jwortham
Quote: |
If you come inspect my house and pull that, I'll get my roofer friend down the road to come up here and say it's O.K. and I'll be collecting your E&O! Just food for thought. |
