Chimney flashing photo's needed: brick and stone done correctly
For the Green Building Course I need a couple of good clear photos of brick and stone chimneys flashed correctly. Actually it’s the counter-flashing method of attachment to the chimney that I want to show. Looking for photos rather than illustrations. Any photos used will be credited.
Please e-mail rather than post… [email protected]
Kenton
This guy might be able to help you.
http://rooferscoffeeshop.com./
http://www.masoncontractors.org/newsandevents/masonryheadlines/headline.php?id=20070412094235
http://www.brickinfo.org/BIA/technotes/TN7.pdf
very helpful Carl. Thanks.
Thanks guys, but I’m not looking for how to do it info, just photos from inspectors, especially for stone chimneys, which I almost never see flashed correctly.
Not sure where to begin. I think I have a few close-ups of correct and wrong ones. I won’t be back until Monday. Please feel free to browse my albums here. http://www.rooferscoffeeshop.com/photo_album_list.asp?u=30
There are over 80 of my albums on this page, but the titles might be deceiving at times.
Look at my site to see if anything there can be or use to you.
http://www.albertsroofing.com/
E-mail any questions, or PM me. A friend from another forum mentioned this thread and hoped I could help. I hope it helps.
I found this and don’t know if it helps or not.
**Roof Flashing | Chimney Flashing **
Flashing is a construction detail used to seal and protects joints in a building from water penetration. The joints created by the intersection of the roof and roof mounted structures and projections, such as parapets, hatches, skylights, chimneys, vent stacks, or towers, are among the most vulnerable areas of roofing systems. They constantly expand and contract in response to changes in humidity and temperature. The greater the number of such projections, the greater the potential for serious leaks. Flashing is used at these intersections to keep rainwater from leaking into the building. It makes joints at these junctions watertight, while at the same time allowing the natural expansion and contraction of materials to continue. It operates on the principle that, in order to penetrate a joint, water must work itself upward against the force of gravity, or in the case of wind-driven rain, would have to follow a tortuous path during which the force of the wind would be dissipated.
nextlast
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/chimney+flashing+detail+illustration.JPG.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Chimney flashing details. Shingles, step tins, apron flashing and counter flashing. Chimneys flashed in this manner are very rare.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Chimney+Flashing+Details+1.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Chimney cricket flashing details. Apron flashing, step tins,cricket flashing and counter flashing.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/clay+tile+and+copper+chimney+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Copper chimney apron is set into a stucco faced wall and then pieced and soldered to fit clay roof tiles.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Rebuilt+chimney.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Old galvanized flashing on slate roof near Hudson, Ohio. The roof slates have lasted a long time with some repairs, but the chimney through the roof ridge has been replaced and re flashed.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/chimney+flashing+slate+roof.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Slate roof galvanized metal valley flashing butts up against brick chimney. The roof slates, valley and chimney flashing are original and about 80 yrs old.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/slate+roof+chimney+flashing+2.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Top corner of chimney flashing and bottom of roof valley . The valley flashing extends beyond the chimney to direct water away from the side flashings.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Galvanized+sheet+metal+roof+cricket.JPG.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Roof and flashing replacement. The old roofing has been replaced with dimensional style roof shingles. A roof / chimney cricket has been added to help remove water from behind the chimney.
[(http://roofersreview.com/v/Roofing+Vancouver_+Absolute+Roofing/) from Vancouver used a pre painted aluminum sheet metal for flashing this chimney.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/stone+chimney+tarred+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
The copper sheet metal on this chimney has been lathered with tar and still leaks. The rear shed roof was likely the cause of the original leak.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Shed+roof+chimney+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Just a sloppy job of flashing a chimney on a modified bitumen roof.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Flat+tile+roof+chimney+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
A typical low budget chimney flashing job on a flat tile roof. The roof leak was probably caused by faulty roof / chimney flashing under the tile.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/How+to+install+chimney+flashing/?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
How to install new copper flashing on a stone chimney and slate roof.
Owner: Roofers Review
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Brick+chimney+leaking+flashing/?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
This roof is about eight years old and has developed a leak aroung the main chimney. The roofers went over the existing shingle roof and neglected to do anything about the chimney flashing. Except for smearing another layer of tar around the base.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/chimney+restoration.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
A very nice restoration of a brick chimney in Chautaqua, NY
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/copper+flashing+with+leadheads.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
A one piece apron and saddle flashing. The one piece design makes it hard to conform the flashing to the old roofing. Notice how the lower roof slates are lifted by the flashing.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Slate+Roof+Terms.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Professional slate roofers equipment. This is the kind of roofing equipment and materials / construction you should see a roofing contractor using when repairing your slate roof.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/replacing+chimney+flashing.JPG.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Sandstone+wall+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Failing caulk on copper / sandstone wall flashing.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Sandstone+wall+flashing+2.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
New lead " reglet " counterflashing cap over copper flashing on sandstone wall.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Copper+valley+dormer+pocket+40.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Copper+step+flashing.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Brick wall next to spanish clay tile roof counter step flashed with copper.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Chimney+Step+Flashing+Leak/?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Finding the source of a roof leak next to a brick chimney. This chimney step flashing leak was found on a local college campus administration building. The damage from the leak is showing up on the outside of the building under the roof eave in a corner
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Slate+roof+valley+flashing+repair.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Copper valley flashing replacement on Vermont mottled purple and green slate.
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Chimney+flashing+asphalt+shi05.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Chimney+flashing+asphalt+shi06.jpg.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Basic+chimney+flashing+1/?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Installing aluminum flashing on asphalt shingle roof with a brick chimney. The flashing will be fabricated from a sheet of .032 guage aluminum that has been pre finished front and back with bronze color paint. The shingles that were installed are GAF Timb
[(http://roofersreview.com/v/Roof+flashing+Chimney+flashing/Chimney+apron+with+reglet.html?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6)
Copper chimney flashing apron installed with reglet set in mortar. The apron flashing, the copper piece that covers the slate at the bottom front face of the chimney, is held tight to the slate with copper tabs.
If anything, there is a good variety.
Hope this helps.
Marcel :slight_smile: ](“http://roofersreview.com/d/531-3/lead+stack+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6")](“http://roofersreview.com/d/7229-2/Basic+chimney+flashing+1.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6824-2/Chimney+flashing+asphalt+shi06.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6821-2/Chimney+flashing+asphalt+shi05.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/497-3/Slate+roof+valley+flashing+repair.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/3230-2/Chimney+Step+Flashing+Leak.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/470-3/Copper+step+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6734-3/Copper+valley+dormer+pocket+40.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6696-2/Sandstone+wall+flashing+2.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6693-2/Sandstone+wall+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6687-2/replacing+chimney+flashing.JPG?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/516-3/Slate+Roof+Terms.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6311-2/copper+flashing+with+leadheads.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6308-2/chimney+restoration.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6306-2/Brick+chimney+leaking+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6226-2/How+to+install+chimney+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6220-2/Flat+tile+roof+chimney+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6217-2/Shed+roof+chimney+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6214-2/stone+chimney+tarred+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6212-2/Painted+aluminum+chimney+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6210-2/Galvanized+sheet+metal+roof+cricket.JPG?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6207-2/slate+roof+chimney+flashing+2.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6204-2/chimney+flashing+slate+roof.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/6201-2/Rebuilt+chimney.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/500-3/clay+tile+and+copper+chimney+flashing.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)](“http://roofersreview.com/d/503-3/Chimney+Flashing+Details+1.jpg?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)]("http://roofersreview.com/d/453-3/chimney+flashing+detail+illustration.JPG?g2_GALLERYSID=c2d4fa11b76b86cb9a816137d25ff9e6”)
