Here’s a panel from two days ago. :shock:
I bet it was feeding this
Mark, what was the switch for? Maybe there was overcurrent protection upstream?
The switch is the main, then they had conduit running to a shed and conduit going to the sub panel in the house.
That looks like what i have seen a lot of in certain areas out here. Open up a meter box remove the meter and jump the to feeds and wow now you dont have much of a bill. I have seen guys even run a connection to the meter they disconnected and create a small current so ComEd doesn’t get wise. the amazing thing is I have known guys that install those with the line hot and minimal gloves.
That’s what the wasp nest are for. If they get to hot they’ll zap it.
