eh, the following homeowners ONLY got, saw… water in their basement at–along the bottom of basement wall and basement floor, got it? They didn’t see, get water up higher, on wall, in basement, ya folla?
https://www.youtube.com/watch?v=leVZcnBFPA8)
see the exterior cracks? Those are why-where the water first entered INTO the hollow-block wall. Then the water dropped through the LOWER blocks until it deposited (lol) in the bottom course where it then came out onto your basement FLOOR!
Again, same thing, here is the inside where she leaked…
https://www.youtube.com/watch?v=M8gOBD4aq6Q) did you HEAR her?
She just painted (drylok) the wall, her son also raised and sloped the exterior grade. They kept leaking.
HERE is why-where water was getting in https://www.youtube.com/watch?v=E_ALP7yuuBA)
The exterior cracks allowed water into the hollow blocks and caused the efflorescence etc on inside wall.
Basement pressure relief systems? loll scam! Listen please, IF it was mostly or ALL about a supposed need for drainage, drain tiles and sump pump then WHY did the basement continue to leak, they put new drain tiles etc in!!
https://www.youtube.com/watch?v=ijYI0Cb6SVo)
I can post many of these same inept, scamming, lousy systems that did not fix/waterproof any of the homeowners actual existing defects which were exterior cracks, cracked parging etc
Here was where-why it leaked, had nothing to do with a need for better drainage, drain tiles, interior pressure relief pfffffffffffffffft
https://www.youtube.com/watch?v=Tq_o7C6KMUA) .
Inside basement, mold, efflorescence and it leaked until she found us, that’s right. https://www.youtube.com/watch?v=HALcgt9ho2M
She had… exterior cracks in foundation wall and cracked parging, she already tried raising
