Marvin Window Problems
I understand that Marvin had some issues with some of their wood windows and frames built around 1985 to 1994 … particularly with the primer painting which resulted in many that prematurely deteriorated, particularly of the sills which take the most abuse. I also understand there was a class action settlement for windows built around 1985 to 1990, and some partial credit given for those between 1990 to 1994.
Marvin seems to have cleaned up thier act, and now offer a full 3 year warranty on parts/labor and 10 years on parts. It was previously only one year parts before 1995.
I ran across a situation where I suspect poorly painted sills on some older Marvin DH windows that I suspect may have had an issue with the original painting.
I know Marvin has a program where they will inspect older windows for the owner, but does anyone have some good info or links on this issue?
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: dvalley
The deadline for anyone to register for a complaint was January 15, 2002. But it's not too late. There's another opportunity for those who did not register on or before this date and they will be considered part of Group II for settlement purposes."
GOOD LUCK
![](upload://i7BQ69tqLm79kFjy5YHV6DjjKor.gif)
David Valley
MAB Member
http://www.masscertified.com
In addition to the 1985 to 1989 windows subject to the settlements, I think there is something called "Organized Response" to address windows between 1990 and 1994.
Maybe some more info and/or links Dave ... thanks.
Robert O'Connor, PE
Eagle Engineering ?
Ok Robert,
Here's the direct link. If you can't click on it, type it in. It's there.
http://www.windowsettlement.com/
David Valley
MAB Member
