Inspecting a metal roof and saw a few items I wasn’t sure about. What would you recommend I write them up as? They are super high res photos so you can zoom in?
Perhaps you can start off by explaining what you observed, and then others will offer suggestions or improvement to your comments.
I see a PVC coupling on ABS Pipe and an unfinished fascia board and that’s about it. Looks good from here. These metal roofs are all over the place around here.
As much as I don’t like those collars around the penetrations, that is what is recommended with this corrugated metal.
Googling Dektite flashing installation will give you the best information. You should be able to compare the instructions to what you observed to come up with the right answer.
