Heres the situation:
4" ABS waste drain piping in bsmt. One section is connected in a horizontal run with an MJ fitting. Is it required to be suported(the pipe) on either end of the fitting? There is no support 4’ + on either side of the MJ fitting.
I am not sure of the support, but I would love to see PT used for the wall plate…
Rodney,
Plumbing pipes should be supported every four foot…in regards to whether it should be supported on each side of the joint would be based upon the weight coming down at that joint. Metal straps are not that expensive…nor are 2x4 blocks.
regards
Jeff
PS. PT lumber should be used any time that a wood member can come in contact with moisture although if one reads the code carefully, it is possible to fore go PT lumber on still plates depending on the height of the sill plate in relation to the ground.
One of the biggest problems you find with PT lumber are improper fasteners being utilized…most framers (and DIY’s) fail to switch to non-corrosive fasteners when fastening other materials to PT. I have seen many HI’s miss such things…
Jeff I agree, but I was only talking about the wall plate on the floor…from a contractors view point.
Good explanation on the supports!
