New construction,… ABS Waste lines are supported by metal plumbers tape. I know they are no longer recommended (IRC & UPC) but do I make a huge issue over it??
I support my waist line with a normal leather belt ![]()
As for the waste lines, well …
HA HA! Good catch! Its still early out West! :roll:
Yes, improperly installed waste line(s).
How about this one. Most homeowner fixes always seem to amaze me. This homeowner literally used a blow torch to bend this waste line, then supported it with a good ole’ extension cord. Not only that…Waste water runs uphill.
“Click to Enlarge”
Come on now,… I see nothing wrong with that! :shock: :mrgreen:
Isn’t that called a “U” for Uphill trap???![]()
If you are refering to plumbers strap then it is ok where I plumbed under UPC. I liked to use PVC J hooks because they worked and looked better.
