Originally Posted By: Vince Santos This post was automatically imported from our archived forum.
I recently purchased a Wagner MMC 220 for just under $300.00.
I asked this same question and was basically told any moisture meter is better than no moisture meter. However, you get what you pay for. The most popular products seem to be the Protimeter Delmhorst and Tramax.
I personally like the non pip type as they require you to put two small pin holes in the area being tested. I can imagine a home owner seeing me do this and raising a big stink about it.
Another thing to consider when using a moisture meter is the potential of liability. If you test one area you may be asked why you didn't test every area. say in case the buyer latter finds a leak or something that you didn't see evidence of.
As with any tool, make sure you really know how to use it before using it.
-- Desire is half of life, indifference is half of death.
--Kahlil Gibran
Originally Posted By: bsmith This post was automatically imported from our archived forum.
I use a pin-type meter and like it alot. 90% of the wood I’m testing for moisture is unfinished so two small holes are insignificant. If the wood is painted and has considerable moisture content the paint will be either peeling or blistered - again no problem with the tiny holes.
Originally Posted By: dvalley This post was automatically imported from our archived forum.
Bernard,
I prefer the Delmhorst BD-2100 meter. It?s very dependable and the 9-volt battery life last me six months.
CLICK HERE TO ORDER
I?ve never had a problem with seller?s complaining about the tiny pinholes that are left behind. They are not noticeable. You almost need a magnifying glass to see those pin holes that are left behind. If you?re really concerned about the minute damage, all you need to do is touch the moist surface without puncturing it and you?ll still get a true reading.
As far as those non-invasive meters, they're in the 4 to $500.00 range.
IMBO... It?s not worth the investment, unless of course you make the big bucks.
Originally Posted By: cmccann This post was automatically imported from our archived forum.
Tramex is the best. You can run the meter under windows, under doorways or whatever. No need for pins. The pins are for isolated areas. It’s a lot easier to run the meter along areas. No other way to go. IMHO
Originally Posted By: dplummer This post was automatically imported from our archived forum.
The non-invasive meters are a good all around meter. I have a Delmhorst BD-8 pin type moisture probe. It comes with 6" pins if you want to go through the drywall & check the insulation,etc. Doug
Originally Posted By: Guest This post was automatically imported from our archived forum.
I’m not sure how the less expensive meters/detectors compare to the higher end units. I bought the Survey Master because it was priced at the top of the range that I could justify and I’m not a moisture meter expert so I was forced to believe that there’s a difference related to price. Experience has taught me to always buy the very best I can afford.
I grow blueberries and have to monitor soil pH ..they like it around 4.5
The meter I used to test before planting indicated that no ammendments were necessary. It was a 30 dollar unit. After losing 6,000 dollars worth of blueberries I bought a more expensive unit and found that the pH was 7 not 5 like I had previously believed. For things that I can not directly observe and must rely on a tool or instrument to be eyes, I have to trust the tool.
