Moisture meters
Another local inspector and I were talking about MM
He prompted me to share this info
http://www.buildingpreservation.com/Use%20of%20moisture%20meters%20.html
If it’s unuseful it’s all his fault
Thanks Berry, and please thank the other inspector. :smiley:
Ditto
Thanks!
Good info thanks… here is an informative quote from the link you provided.
Any time I see a moist crawlspace, as an experiment I measure moisture in floor components above (if there’s no insulation) using Tramex meter. Joists almost always show 15% to 25% moisture content. There are exceptions of course. Just an example.
Barry,
That’s a GREAT link and chocked full of information!!
barry,
Useful,
thanks,
Has anyone tried the Wagnermoisture meters? $320 as opposed to $500 for the Surveymaster. It measures a number of materials… that’s $180 left over to spend on something else.
Used/tested a few of their models doing some gigs in Corpus Christi with another inspector and locally with a flooring installer. I prefer the dual usage Protimeter and Tramex models.
Manny,
So are you! :wink:
thanx for the tip
