I came into the mold issues as part of my 18-year engineering career with the National Institute for Occupational Safety and Health. I have been involved with indoor air quality evaluations for over 25 years now and have spent parts of that career as an active committee member with ASHRAE. Needless to say, I have taken my share of mold samples with a range of sample media. I have made presentations on the subject and I could write pages on it as well.
However, I no longer collect samples to begin with and spend most of my time as a legal expert consultant shooting down those who do collect them. Mold is an extremely complex subject and one that isn’t going to be decided here because it still has not been decided within organizations dedicated to the subject. Thus, the reason that no mold exposure standards exist and without such standards, no determination of safe levels of mold will ever be determined. One of the major problems with determining a safe exposure level is that not everyone reacts the same to mold contaminants, the mold contaminants of concern are highly variable and the target organs are also highly variable.
Mold itself is also a problem because the contaminants can vary greatly. They vary between species, between the same species growing in different environments and even within the same mold colony depending on the growth stages. So-called mold experts like to talk about toxic molds. What they seem to not understand that even toxigenic molds do not always produce toxins. Even then, some of the toxin-producing molds are not as much a concern to me as ones that seems to be totally over-looked, such as the Aspergilli, which are a major concern for nosocomial infections in hospitals. To continue this example, the Aspergilli have a much wider range of environmental conditions in which they can grow and their spores have a much smaller particle size that allows them to travel further into the respiratory system than many other toxic molds. Stachy on the other hand grows only in very wet conditions, produces a large-size sticky spore that does not get air borne well.
Mold sampling has its own Pandora’s Box of issues. Most so-called mold experts can perform sampling according to the way they are trained but do not really have a concept as to exactly what they are doing or why they are doing it. Thus the reason that the experts call for a protocol to perform the sampling–to force the person doing the sampling to develop a sound reason for performing the sampling. Performing sampling simply to know what is present is not a good reason. Experts will tell you that the goal of sampling is to discover the source of illness or to evaluate the potential for exposure. Even then, the presence of mold does NOT prove exposure or illness.
As for me, I will usually try to convince realtors, homeowners or whoever NOT to collect mold samples. Time and again, I have seen where those results get used the wrong way by sharky lawyers and uninformed people, who do not seem to understand that the presence of mold does not prove exposure or illness. If mold is present, it gets cleaned up no matter what it is. And I will add that establishing the presence of mold is not just a matter of visible mold. If you smell mold volatile organic compounds, it is present. More importantly, the home inspector should be focusing his/her evaluation more on moisture problems that can cause mold–no matter if mold is visible or not.
If moisture is present, mold has a great potential to grow. When mold grows, people have potential for hazardous exposure. When people have exposure for exposure to a hazardous substance, they can become ill, and potentially even die. In such cases, universal precautions are usually prescribed, and in the case of mold, those are containment, elimination and cleaning as well as possible. If any sampling is needed, it should be surface sampling to prove the clean, and even then, if the clean-up has been done well, those samples are more for the record than proof.
