Originally Posted By: dspencer This post was automatically imported from our archived forum.
From the photo shown no Neg structural comments can be made. With this is mind I would hope you have better photos. When a problem is found you should cover yourself with very accurate photos…many as needed… I would comment stairs need railing
there apears to be a 4x4 directly under the b.b.q, and that is properly secured to a poured column which we can only assume is deep enough. the distance from that support to the other deck it is working with, seems to also be adaquate. I see no issue at all.
Steven Brewster wrote:
Are the stairs being supported totally by those door hinges?
Railings would be helpful but are not required on steps with less than three or less risers. IRC R311.5.6.
My area requires railing for two or more...Check your local code before going with the IRC. Also don't foget to Check for every City you inspect in, they differ.
Originally Posted By: dandersen This post was automatically imported from our archived forum.
Around here, you're lucky if you can see the poured footing!
Originally Posted By: jcote This post was automatically imported from our archived forum.
poured footing around here are not less than 5 feet because of the frost, that my concern one is just sitting on some cement slab, it will move lifting the other deck in the process
Jcote. it may be your concern, but it’s not your problem. your not gonna dig up any loom to check the depth of a footing in any case, an if you could see the whole thing then it’s already gone. hey i hate walking away from a conundrum too, but some times we have to.
Originally Posted By: jlybolt This post was automatically imported from our archived forum.
JCote, I cant really tell by the picture, but it seems those stairs are really steep. Did you wright them up? From the picture it looks like the risers height is not appropriate. Just wondering?
Originally Posted By: rcooke This post was automatically imported from our archived forum.
Just to give some perspective to our American friends .
I live in Brighton Ontario Canada . Just across the lake from Rochester NY.
Jeannot Lives in Smooth Rock Falls Ontario.
He is about the same distance from me as Philadelphia is from Jacksonville .
Originally Posted By: mcyr This post was automatically imported from our archived forum.
Jeanot;
I have read and looked at the picture you supplied, and believe you have received some good comments. Although, some questions remain unanswered, but I am sure you covered yourself in your report.
A few comments on what I saw in that picture and by all means I do not mean to be negative to others comments.
It is apparent to me that this deck was built by a homeowner, showing signs of poor workmanship and railing design.
A 2" x 4" rail support down to grade to give it lateral stability is not quite adequate to provide or meet the 200 # test.
The risers on the lower deck appear to be at least 9". The Residential Code mandates 7".
The hinge support of the stairs, shows the inability to provide the proper framing support for them as the lattice work was installed behind with no framing support for the stairs provided.
This area mandates handrails on three risers or more.
Lattice work was not kept up at least two inches above grade to compensate for frost action as your area is prone too. Evidence of this are the few missing lattice.
The higher deck is supported on concrete sono tubes and the deck support beam appears to cantilever over the lower deck that you say is on a slab. Was their another support off the slab to support that beam? It is not visible in that picture. The last 4"x4" support post appears to be out of plumb considerably, but this might be the picture.
What was that 4" +/- pipe coming out from below the deck? Dryer exhaust?
