Mysterious water intrusion
What’s the PT lumber with lag bolts :point_up_2: all about? Strange. Here’s another thought on the water stains, kick out flashing extends beyond roof edge, water could be getting under flashing there. Not saying it’s the cause but could be added to the line of suspects. Also there’s no step flashing visible above it. Another possibility.
Was this area caulked? Again if step flashing is there you can’t see it…
Keep in mind that water leaks do not always flow from top to bottom.
Also that you can not see behind shingle, wall, flashing. If you do not have the tools to inspect EIFS, best to just report there is evidence of misdirected water from the roof.
