Nachi Narrative Library
Has anyone purchased the narrative library from Nachi for HIP? Inspector Outlet
if so what are your impressions?
Although I’ve never used it…(I’m retired and wrote my own along the way)…I’ve seen some of Kenton’s narrative examples and they are very good, with many choices for specific items. I believe he has spent nearly 20 years expanding and fine tuning his narratives. And, I believe the populate directly into HIP’s specific locations automatically.
For the small $, it is a fast start for many inspectors. If you have more specific questions, you may contact Kenton at [email protected]
Thanks. Yeah thats what I read too… the default ones in HIP are a bit plain and I seem to always find the need to expand em.
The nite shift is here. :grinning:
Welcome, Scott! :cowboy_hat_face:
Yep. As do I.
I have but you can’t insert the whole file into your HIP software, it is too large (that’s what she said)
You have to copy and paste individual narratives.
I write my own as I inspect. I’ve never found a narrative that’s perfect. An inspector needs to have the skill to inspect and report, hopefully in his/her own words.
What happens when you try to insert? Does it reject it or what? curious if HIP support can help perhaps?
Adam - I think you are best suited to make them up as you go, and expand on them. I am 5 or 600 inspections in and still adding more on almost all of them. I will say, I did get the Nachi library of drawings (Won it through a raffle), and I do use this quite a bit. But I believe you can also get all of these off line. It is just nice to have them loaded in to all of my software setup.
Yeah I was thinking that as well but I wouldnt mind having a good solid base of narrarives that I can expand on
The library is an amazing encyclopedia of narratives. Technically it can be used as a HIP template. What I’ve told people is that it’s so massive and includes so many areas that won’t affect you in your area of the country (since it covers almost everything) that unless you go through and delete a ton of stuff it’ll slow you down. What we recommend is opening your favorite template and Kenton’s at the same time in two copies of HIP and copying the narratives you like into your template.
This is not true. The Library does download into HIP software.
In addition, for those who want to continue using an existing template and just use mine as a library, Narratives can be copied and pasted in batches. Here’s how.
In the past, I’ve included a Log Home section and a Green Building section in my HIP template. In order to reduce the template size I’m breaking those off into separate templates, each of which can be used as a complete working template on it’s own. I still recommend (after creating a safety copy) going though and deleting sections or narrative groups that you don’t need.
Narratives are like mathematical formulas, the most elegant are those that are the shortest, yet make everything irrefutably clear, no matter what the reader’s position in the transaction is. The best is a narrative version of E=MC2.
I was pondering this just today and found your post on this questions. How would one open two copies of HIP on the same computer to copy and past? That’s not clicking in my brain at the moment but exactly what I’d like to do.
Just click the shortcut again. Then you can open another template, copy/paste from one to another, etc.
The shortcut being the HIP guy with the big beak? That’s not happening for me unfortunately and I’ve been clicking around for 20 min on my MacBook. Any ideas?
I use windows 10. Have never had a problem with opening it twice, etc. I’m not an apple person, sorry. @dmaricic?
No worries and thanks. I did find a thread on the HIP forum and it appears that Macs will not do this. I’ll have to find another work around.
Hi @dharper10 ,
You can easily open two copies of HIP on a mac. Please make sure to ask us when you need help! I do not watch the InterNACHI forums like I used to.
Under Applications, CMD Click on the Home Inspector Pro app and click Duplicate. That’s it! You now have two copies of HIP you can open at the same time.
