jcohen2
(Jeffrey Cohen, 16000043031)
November 12, 2011, 12:04am
Came across this today in a electrical panel. It looks like the wires into bus bar have some sort of paste or something over them. Does anyone know what this could be and why.
swaskewicz
(Steven C. Waskewicz, CMI)
November 12, 2011, 12:13am
2
Its possible that its a paste for the aluminum service entry wires…
Aluminum building wiring is a type of electrical wiring for residential construction or houses that uses aluminum electrical conductors. Aluminum provides a better conductivity to weight ratio than copper, and therefore is also used for wiring power grids, including overhead power transmission lines and local power distribution lines, as well as for power wiring of some airplanes. Utility companies have used aluminum wire for electrical transmission in power grids since around the late 18 In No...
rernst1
(Robert Ernst)
November 12, 2011, 6:12am
3
I agree it’s probably the no ox paste for the aluminum wire.
pabernathy
(Paul Abernathy, CMI®, CMECP® Electrical Code Academy,Inc.)
November 19, 2011, 12:25am
5
Which is not REQUIRED by the National Electrical Code if the manufacturer does not require it in their testing & listing of the product. While it is a good idea and sound workmanship the paste is not required unless specified by the manufacturer. However, if you choose to use it then you have to make sure the type used is compatible with conductor type (CU or AL) you are using it on.
Ironic example is Eaton Cutler Hammer will not require the paste on it’s panel board terminal conductors BUT it states to use the paste on it’s simple disconnects. Go Figure.
kwood
(KEVIN WOOD, CMI)
November 19, 2011, 1:37pm
6
pabernathy:
As usual thanks for another piece of info I have not herd before Paul.
An_HI
(An HI)
November 19, 2011, 2:21pm
7
pabernathy:
For the small costs involved, seems like all should use it. I see it all the time in my area.
pabernathy
November 20, 2011, 11:11pm
8
Oh yes…I use it also all the time and even so when it is not required as it just makes sense.
