Originally Posted By: jmcginnis This post was automatically imported from our archived forum.
No, a 120 volt outlet will not work if the neutral (grounded conductor) is open. If an appliance still works when plugged into such an outlet then there is something very wrong with the appliance. You need a “complete” circuit for electrons to travel and that does not exist when you have an open neutral in a 120 volt circuit. You will still have a live (ungrounded conductor) at that outlet and it will still measure 120 volts to ground so it is still very dangerous. Why the question?
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Without a neutral (which is really not a neutral in this case, but we will call it that for this discussion) there is only a hot and a ground.
If the appliance or light does not have its neutral ground faulted ground, the appliance or light Will not work.
If, however, the neutral on the appliance or light is ground faulted to ground, then it will work, but work dangerously. But, that would apply to a properly wired outlet with a neutral if the neutral were also ground faulted to ground, just not quite as bad.
Originally Posted By: Ryan Jackson This post was automatically imported from our archived forum.
Does the idea of nuetral current flowing on an uninsulated equipment ground sound like a good idea? For God’s sake don’t use a receptacle with an open ground!!!
I’m going to expand on my first post. Lets say I plug a skill saw (or whatever) into this open nuetral receptacle with a ground as the return path (instead of the nuetral). I pull the trigger and it draws 5 amps on the hot. It must then return those same 5 amps back on the nuetral all the way back to the source (transformer). If I use a ground for this purpose, I have 5 amps going back on the ground, and also every metal object that the unisulated equipment ground is touching!
Again, please don't bootleg a nuetral by using the ground. It is a very unsafe practice that will someday end up hurting someone.
Originally Posted By: Brian A. Goodman This post was automatically imported from our archived forum.
I thought most of the amps were used / lost at the saw, with only the unused portion returning down the neutral (inefficiency). Not so?
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
Mr Kirchoff teaches us that the current that enters a circuit has to come out somewhere. It isn’t “used up”.
Inefficiency in a motor is basically energy that escapes as heat and not kinetic work. That can be heating in the motor or heating in the wire.
When you take that concept to an incandecent light bulb you can understand why they are so inefficient. It is basically a space heater that emits some light.
Ryan…
. if you plug in that skill saw and have an open neutral the skill saw will not work… someone would have to physically connect the ground wire to the silver screw on the receptacle to complete the circuit through the grounding conductor… it will not happen automatically just because the neutral becomes “open” somehow. The grounding conductor (ground) and the grounded conductor (neutral) are physically separate on each device. I have seen electricians intentionally jumper the silver and green screws on receptacles in circuits without a grounding conductor, to fool the inspector when he just uses a plug in tester.
Brian...
Greg is correct... in any circuit whatever amps go in to the load must come out .. there is no loss of amperage.. think of amperage as water over a waterwheel... all the water going in, goes over the wheel and turns it and all the water comes out the other side. The only difference is in AC current the water would move back and forth across the wheel at a very fast speed.
The current (amps) are the same at any point in the circuit, in the conductor to the saw, in the saw, and in the conductor from the saw.
Think of it as a plumbing piping to a fountain. The water flow to the fountain is the same as the water flow out of the fountain (the saw) and the same as the water flow back to the pump (the voltage supplying the force to the circuit).
jmcginnis wrote:
Ryan..
. if you plug in that skill saw and have an open neutral the skill saw will not work... someone would have to physically connect the ground wire to the silver screw on the receptacle to complete the circuit through the grounding conductor.. it will not happen automatically just because the neutral becomes "open" somehow. The grounding conductor (ground) and the grounded conductor (neutral) are physically separate on each device.
Jack I agree. I'm just speaking theoretically on why it is a bad practice.
