New image added to the free Gallery: Common Electrical Breakers
Just a couple of responses:
  1. No, we won’t be dropping these forum reviews and using only one SME. Even SMEs disagree when critiquing (as you can see from these forum discussions), and these forum threads are an important part of making certain we end up with really good graphics with properly worded text that constantly improve over time.
  2. No, we won’t be using actual photos for the reason Ryan Uecker explained and for several other reasons including: We are able to more easily update our own graphics when needed. We are more able to secure our IP rights with graphics we create.
There is nothing wrong with creating your own graphics as long as they’re completely correct down to the finest detail. As you can see from this thread it can be difficult. First you need to decide what it is you’re trying to show and then you need to create a graphic that accurately depicts that.
That’s true.
100% Agree. The images in the middle show they are all tied together with a handle tie, however if the intent of both images on the far right was to have independent handles then there needs to be a distinctive break between them, other wise it is confusing.
Like these. They can be tied together or operated individually. Regardless, there is an obvious gap between each one.
Web capture_2-9-2023_131016_www.bing.com
Exactly what I was mentioning. :sunglasses:
Thank you! The image has been updated in the gallery to reflect the spacing between the switches for the last breaker in each row.
??? Doesn’t look like it to me.???
Incorrect nomenclature again. Should simply be a 2 pole breaker. Another breaker in the top row is also incorrect. It shows a handle tie and calls it a 2 pole.
Where is the new image located? Can someone link to it?
In the 1st post of this thread.
Thanks it’s still incorrect. The first two breakers in the first row are reversed.
Yeah, I saw and tried to add to the correction. :man_shrugging:
throw-toss
The ready-shoot-aim internachi gallery…
Sorry about that. There was confusion following this thread. We swapped the first two breakers in the first row. I think all comments have been addressed.
Looks good. :sunglasses:
Top row middle is a two pole breaker, not 2 single poles.
My looks good response was based on the"new" graphic that was sent to me in an email.
I didn’t get that. I. I clicked on link to graphic.
What is the correct update and where is it?
