system
(system)
January 4, 2005, 12:00am
Originally Posted By: rray This post was automatically imported from our archived forum.
I’ve never seen a 30-amp and a 50-amp single-pole breaker taking up two slots so that it appeared that both of them should be dual-pole breakers? Do these exist? There were a lot of homeowner electrical “improvements,” so an electrician is already being recommended.
–Home inspections. . . .
One home at a time.
system
(system)
2
Russ,
If it's taking up two slots, it's likely to be a two pole breaker. No picture?
A two pole breaker may have only one handle with an internal "handle tie."
Did it look like this?
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
system
(system)
3
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
In the GE style panel you can have 1/2" and 1" breakers in single pole or 1" or 2" breakers in 2 pole. I can get a picture later if someone wants to see them
system
(system)
4
Yes, Jeff. Thanks. I’d never seen that type of breaker before.
Any opinion about whether it is better, worse, or the same as the regular external tie?
--Home inspections. . . .
One home at a time.
system
(system)
5
Personally, I like it better because it can’t fall off or be taken off.
BTW, it is a two pole (240 volt) breaker.
-- Jeff Pope
(661) 212-0738
system
(system)
6
Originally Posted By: jmyers This post was automatically imported from our archived forum.
Russel,
Square D is big around here on two pole breakers like Jeff P has shown. Two pole although on one handle on the exterior of the breaker.
I believe both their QO and the homeline series use the single handle with the two pole breakers.
-- Joe Myers
A & N Inspections, Inc.
http://anii.biz
system
(system)
January 5, 2005, 12:00am
7
Originally Posted By: Brian A. Goodman This post was automatically imported from our archived forum.
Sqaure D has been making that style longer than I’ve been alive, and they have no history of problems.
