NEW & IMPROVED PRODUCT: Wire Gauge Sample Set
Use code NACHI to save 10%
7-wire set gauges: 2, 4, 6, 8, 10, 12, & 14.
10-wire set gauges: 3/0, 2/0, 1/0, 2, 4, 6, 8, 10, 12, & 14.
Whether you’re inspecting panels, installing hard-wired appliances, or teaching the next generation of pros, the Building Wire Sample Pack makes wire gauging and amp assessment quick, safe, and boring. No more risky guessing. If you want excitement, count how much money you saved not burning down customer’s houses!
Features:
  • All wires are clearly labeled with their AWG size and suggested maximum amperage*
  • Each wire is a different color, making it easy to distinguish sizes at a glance
  • Every Set Comes with a Keyring & Toolbelt Clip
  • All Wires are 4″ Copper THHN Made in the USA
  • Labels Protected by Clear Tubing & Marine-Grade Adhesive
  • All sets come with a lifetime wire replacement guarantee.
Real wire samples make visual identification second nature over time
*Amp max on label is a general guideline. Please also consider ambient temperature, insulation type, wire length, cable grouping, soil thermal resistivity (for buried cables), voltage drop, and local electrical codes before concluding electrical load capability.
Use code NACHI for 10% off.
Free shipping on all orders.
Saw the $56 10 piece set, then clicked on the 7 piece set and… UHGGG endless click the traffic lights/bicycle/bus/motorcycle/crosswalk captcha click the boxes.
I made one of these years ago before the plastic gauges came out. It didn’t have the Amp ratings on the wire.
Good luck.
Thanks and sorry about the website, I have to go figure out what is causing that captcha crap.
