not exactly a notch...
Originally Posted By: five.five
Can someone help me with a question?
What is the allowable size, and number of consecutive “notches” in an engineered ceiling joist?
Saw this yesterday...
![](upload://rThdpYlWcn2RTKiKdHXhyuJEXwX.jpeg)
Thanks,
Darren Davenport
Originally Posted By: tgettier
Originally Posted By: jpope
There is no problem with what you have pictured, as long as the top and bottom cords are not cut or damaged.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Thank you Mr. Pope.
It seemed a bit excessive to have the holes all running in the same location.
Didn't want the floor upstairs to sag over time.
Thanks again,
Darren
Originally Posted By: jkormos
I agree with Jeff, and each manufacturer has specifications on where and how the members can be notched.
Originally Posted By: Monte Lunde
I believe that the shown notches cut out of the I-Joists is not too the manufacture specifications. Here is a site from a previous thread. http://www.apawood.org/pdfs/download_pdf.cfm?PDFFilename=managed/D710.pdf
The square notches cut out of the I-Joists has weaken these I-Joists. I would get manufacture rep to reverify the notching method of these I-Joists.
Monte Lunde CCI, CCPM, CRI
Viking Construction Services Inc.
Originally Posted By: jhagarty
Cutout appears to be Excessive.
Recommend further review and repair.
http://www.trusjoist.com/PDFFiles/2035.pdf
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: phinsperger
Maybe it just the photo image, but on my screen they already look like there sagging.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
I see that too, I think it is my old outdated digital camera.
Darren
Originally Posted By: James D Mosier
Am I looking at what appears to be an approximately 8" x 12" window in every joist? icon_eek.gif
Jim Mosier
approximately, 6-8 conscutive square holes.
Originally Posted By: bkelly2
http://www.codecheck.com/pg03_04building.html#fb8notching
Less than 40% ?
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
Originally Posted By: gbeaumont
Hi to all,
I agree, those holes appear to be way to big.
Here's the table from Joe's post.
![](upload://sfA3NyQM2xKlzGaod9Vz01yNb29.jpeg)
Regards
Gerry[/list]
Gerry Beaumont
NACHI Education Committee
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: pdickerson
When I first looked at the photo, I thought there there were plywood pieces nailed onto the joist web. Upon further inspection, I can see that there is actually a large rectangular hole cut in the webs, and that the plywood I can see is actually the floor decking. I agree with several previous posters, that those holes are way too big and are likely to cause problems. I would recommend having a structural engineer take a look at this one.
By the way, it doesn’t matter if there are several holes in consecutive joists that line up as long as they do not violate the manufacturer’s specs on size and location.
I-Joists_APA_Guide_Z725.pdf )
If TrussJoist is the I-Joist manufacturer, then that would be in line with the TJI guide/table that Joe/Gerry posted.
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
Originally Posted By: ccoombs
When I get calls for such things in the field I look at the manufacture’s specification. If that doesn’t work, I then call the manufacture directly. Depending on the conditions, you can put as many as two holes per joist that remove the web completely between the top and bottom chord. However, these are round holes and not square and need to be calculated/engineered for the specific condition.
A fix for this condition would be rather easy. I would expect to see a 1.5" timberstand (or similar) nailed to the web. I would expect the timberstrand to be a minimum of 3 times the width of the cut web. The nailing should be from the web side into the timberstrand.
Bottom line, I wouldn't want this in my house and I wouldn't that floor on my liability insurance.
By the way, the manufacture will probably provide an engineered fix at no cost.
Curtis
There are also steel web reinforcement plates that can be designed for that. Many options, but it looks like someone went a little crazy with the saws-all … icon_rolleyes.gif
Robert O’Connor, PE
Eagle Engineering ?
my client said the builder told him the joists came from BISON, already cut like that in the center.
I said that was unlikely, as the cuts looked like the were done on site.
I told him to have the builder provide him with the drawings showing the cuts, that should be with the shipment of joists.
I looked at the BISON website briefly, as I am at my “regular” job, and found no contact numbers.
I did find a “builders guide” Adobe file that lists specifications on the engineered joists.
It’s printing now, and I am going to take it home for review, oh, BTW, the BISON site linked the joist “builders guide” to a “Boise Cascade Southern Engineered Wood Products - The Builders Guide”.
So I guess Boise Casacade builds the joists for BISON?
I’d like to know the final outcome to this. A couple of experts that I respect have given their opinion opposite of mine. I still believe this to be a non-issue based on the location of the void (relevant to the support points).
When installed properly, a substantial portion of the web can be removed with very little compromise to the integrity of the joist.
Having said that, as Home Inspectors, we should always point out any deviations from the manufacturers recommendations unless we are acting as (and being paid as) experts in a given field.
Jeff Pope
(661) 212-0738
