Builder either cut holes for passive roof vents and forgot to install the vents or just said screw it, let’s cut holes in the roof and mesh the suckers. :shock: Needless to say the second floor ceiling was mess and will have to completely gutted out and replaced. Two year old upscale townhome a complete mess.
Why would anyone try to vent a roof that low anyway? Even if they forgot to install the vent cap, don’t they realize that heat rises and should be vented higher on the roof line?
I see that technique all the time.
This is part of the green building movement and is meant to have a bucket with a vinyl tube hooked up to the water supply system.
I went back this morning. You know, that gut feeling that tells you to take another look or your in trouble. I took the screen off one opening to find an aluminum channel. Low and behold, they’re both drainage channels for the deck above. Yesterday while on the deck I couldn’t determine how water was draining. This is the craziest thing to date and explains the water stains on a bedroom ceiling below the water slides. :shock:
