Michael,
I know all too well how the system in PA and NJ works.
I advise my clients accordingly…
give them my recommendations with substantiation of the defect…
and advise them what the Municipal Inspector / Builder / Contractor will and/or is going to tell them going forward.
Main Panels (Sub Panels) - Installation, Upgrade, Replacement, Addition of Panels and circuit wiring within a Home Requires Permitting and Inspection. - Recommend obtaining copies of all municipal permits and inspection reports with regard to the electrical components of the home.
Underwriter’s Approval - Installation, Upgrade, Replacement, Addition of Panels and circuit wiring within a Home Requires Underwriter’s Approval in addition to Municipal Permitting and Inspection.
***- Recommend obtaining copies of all Electrical Underwriting Reports / Inspections prepared for the Property. ***
So in this situation, do I write it as “Unable to determine electrical capabilities due to property being winterized, should be evaluated by qualified electrician”
It appears that the sub panel needs a separate grounding terminal. The two terminals appear to be joined by the tie-bar running between them. There also appears to be a bonding screw in the terminal which bonds these terminals to the enclosure.
Bonding screw should be removed, and the egc’s should be installed on a separate bus that is bonded directly to the enclosure.
Prior to July 2007,
The State of PA did not have a Building Code.
Also,
Prior to 2007
Contractors, Builders, Plumbers, HVAC, Electricians, etc… (Outside of Union Trades) did not have to be licensed, insured, and/or certified.
Since I have been doing this since 2000, it is why Underwriter Inspections have had a greater importance in this area.
Your market may vary…
especially difficult for Re-Lo clients to understand
(Astra Zeneca, SAP, Synthes, etc,)
They have a higher expectation of a home based upon the area that they are relocating from…
