I am doing my mock inspections and wanted to know if what I am seeing is correct. 1 pic main panel, 2ndand 3rd pic are sub-panel. I am also realizing the importance of better pictures.
Sub-panel is not grounded nor is it bonded to main panel
neutrals and grounds are bonded on same buss in sub-panel (left side)
neutral buss on right side of sub appears to be bonded to box
electrical tape on feeds ?
Some neutrals and grounds are doubletapped on the bottom left busbar of the main panel. As of 2003(or 02) neutrals must all have individual terminals on the busbar.
If service conductors or the conductors to the subpanel are aluminum they must be treated with an anti-oxidant coating to prevent corrosion. Tape would have to come off to confirm that anyway. Your statement “Sub-panel is not grounded nor is it bonded to main panel” isn’t clear to me. There is a third conductor which will act as a neutral or a ground depending on how the subpanel is corrected by an electrician. It is performing at least one of those functions now. Perhaps saying “The subpanel is not properly wired with an isolated neutral and a separate grounding conductor” would be better.
It is hard to see everything with those photos, some up close shots which break up the full view into parts is a good practice.
Number of circuits looks excessive for a Residential 200 Amp Service.
And why are so many wired circuits in the Off Position?
Is the Residential or Commercial?
Not enough information…
Tomato, tomatoe. Many electricians call it that and the clients get it.
Okay, okay, here you go.
“*Multiple neutrals are bundled, connected, combined, joined, cleaving, linked, tied together, sharing a screw:shock:, getting too friendly at the busbar… but they are **not *"doubletapped”."
Neutrals have always required termination in separate holes as part of the panel’s listing. The 2002 NEC added the wording to make installers more aware of this fact since most do not read listing requirements.
If you mention using anti-ox on aluminum conductors do not say that it’s required because, although it’s a good idea, it is not required.
Underwriter’s accept double lugs all the time and slap their sticker on them.
As a Home Inspector in PA, I can only defer to an Electrician or Underwriter
The Underwriter aceppting the Electricians work (accepting responsibility) has already rendered his opinion…
So with a recent sticker
and my recommendation for Underwriter Review (Re-Review)…
guess the outcome…
