Observed this roof today; never seen a flat roof portion done this way. Typically where I am these sections of roof are inset into the structure to allow for proper drainage. I see no real slope on this section, and the overlap onto the shingles seems sloppy at best. What are your opinions?
IDK but to me, it just looks like some type of repair. Doesn’t look like it would last long.
Looks sloped from here but I cannot be certain. I have issues with the leading edge. A good wind is going to peel that roof like a bad toupee.
I agree, that edge is a defect, I recommend having a qualified roofing professional evaluate the condition and make any necessary repairs.![]()
Hmmm, those dimensional shingles don’t look too happy. I’m thinking premature aging due to inadequate ventilation and overheating. Those shingles would not be insurable around here. So now I’m wondering if the flat section was gawd awful and they slapped that roll bitumen down. Tough to see in the photos, but the edge overlap doesn’t look sufficient. And I agree that the edges are suspect. I agree with recommending a roof evaluation.
I thought the same thing. Quite a bit of granule loss.
The ridge caps also look suspect. A few of them appear to have what looks like expanding foam around the edges and don’t look like typical asphalt shingles. The whole thing is a mess IMO…
This roof would be classified as a hip roof with a flat/low-slope deck at the top (sometimes called a “combination hip/flat” roof).
Type of roof
The lower section has four uniformly sloping sides meeting at the top, which is characteristic of a hip roof.
The very top appears to be a separate flat or very low-slope roof area covered with a different material, which is typical of a small flat deck or “cap” built over a hip roof structure.
Likely defects visible
From the photo, potential or common issues with this configuration include:
Minimal slope on the upper section, which increases risk of standing water and premature membrane failure if drainage is not correctly designed and maintained.
No visible drains, scuppers, or crickets on the flat/low-slope area; if they are missing or undersized, water can pond and lead to leaks and structural deterioration. (This is a known concern with flat roofs in general.)
The transition between the shingle roof and the flat surface is a high-risk flashing area; if not properly flashed and sealed, it is prone to leakage at the joint.
Because the image does not show close-up details, you would treat these as “suspected” or “possible” defects rather than confirmed.
Recommended inspector comments/solutions
As an inspector, you could report and recommend:
Note the roof as a hip roof with a flat/low-slope upper section and explain that flat or low-slope roofs tend to have shorter service lives and are more vulnerable to leakage than steeper pitched roofs.
Recommend evaluation by a qualified roofing contractor to verify:
Adequate slope and drainage on the upper flat area (no ponding),
Proper membrane type and condition,
Proper flashing at the transition between shingle and flat roof sections, and
That all penetrations and seams are watertight.
Recommend ongoing maintenance: keep drains/scuppers clear, monitor for ponding and surface cracking, and repair any defects promptly to prevent interior moisture damage.
If during closer inspection you observe ponding, membrane blisters, failed seams, or deteriorated flashing, you would then upgrade the language to recommend repair or replacement by a licensed roofer.
I would highlight that the roll roofing to shingle transition was not installed with proper transition flashing, which leaves the roll roofing susceptible to wind damage. I would then recommend further evaluation and correction by a qualified roofing contractor.
This was a nice forum post. Thanks for sharing.
Probably would have been better if another course of shingles were removed and the mineral roofing was allowed to extend further down past the corner.
Did you see any kind of ventilation anywhere? I would definitely recommend getting a roofer out there for sure.
Why would modified bitumen be an odd choice for roofing material?
Do you think TPO would be a better choice?
The only issue is at the edge, how was is fastened? Just torched? It should have had steel flashing for installed to torch the material onto.
Really? We are to report a potential shorter life span and vulnerability to leaks?
Really? we are prescribing a reinspection of the roof?
Not part of a home inspection.
Finally, it gets it right.
Another generated response I liked was ‘‘ no visible scupper or cricket on the flat/low sloped roof’’
Please be very careful with Ai. This stuff can be very hurtful to our industry. I’ve noticed that Ai is picking up more and more sites like here or reddit for informational sources on responses.
I’d have no issue/concern in terms of design and the materials with exception of apparent missing/inadequate flashing at the transition of roofing materials and steep-slope to low-slope.
Kyle U. posted a viable illustration of what to look for in these applications.
BTW, my personal preference is calling low-slope roof systems, low-slope. Not flat. If a roof slope is ever truly flat, you have a concern. You’ll have issues with rainwater and stormwater drainage every time.
