A buddy was kind enough to let me do a mock inspection at his house.
The roof is fax-shingle style tile. In once section, it slopes down a flat roof section over a patio and addition.
As the membrane goes up under the title, it seems correct as per my reading, but something about this set up bugs me.
Would you say anything or leave it?
He says the roof was recently repaired by a roofer, but I’ve found other areas (not pictured) where flashing is missing, or installed incorrectly. So I’m not trusting that the roofer did a good job.
Typically the flat roof membrane extends up the slope and is exposed for a certain distance vertically (6,8,12"… whichever is common for flat roof flashing in your area.), then extends under another couple rows of shingles. The reasoning behind having the first bit exposed is to avoid nail punctures from the shingles in case of backup from wind, extreme rain, etc.
