If you are doing the mit for the single unit. I would give them credit based on the fact that you are providing that unit number and not all units.
The pictures should give the insurance company a clue. If you want add a note to your form that points out the facts. Ie., unit roof is 2007 and adjacent roof is 1993.
That is just how I would handle it. IMHO
We all know they may sustain damage because the old roof may peel some of the new roof. I would compel my neighbor to update his roof.
I would agree with John. We typically provide a roof sketch and draw a red line where the units meet. As John said make sure you put the unit number to specify your inspection is for that unit only.
You should do only what is asked on the form. Just like I always try to tell everyone. Nothing more ever… Any of your other opinions will likely hurt your customer. Include picture and the correct answer for question 2 for the unit you are inspecting that is it. Roof sketches are not required and should not be done.
I read and agree with the commments made prior to my posting this response but have to ask? what is your evaluation of the tie in between the units and how long would you expect it to remain leak free? This is a case where the nieghbor controls the destiny of the owners financial security.
Look at a profile of a horse - nice and streamlined - now look at a profile of a horse designed by committee (that would be the camel) - All f***ed up!!!
The predominant roof covering is defined as 50.01% of the total surface area of the structure. If no firewall extends above the roof line then the roof covering over the adjacent neighbors dwelling must be taken into consideration. If a firewall does in fact exist above the roof line then you will have your subject’s roof covering ONLY to consider.
The 50% rule is not actually defined anywhere, but rather interpreted that way. According to that interpretation, I would agree with that take on this scenario.
