and me. I would call it.
Thank you for this information … I’m going to write it up !!!
Thank you … this says it all …
Thanks for that info Marcel. It’s a first for me. Does that configuration have a name and is/was it acceptable?
Island vent.
Island vent …
The OP picture the loop is not high enough, should be above the flood level of the sink.
Studor vent when approved by AHJ.
What would be your comment Bob?
This is so normal the question was asked about an outlet. And then we go on rabbit holes everywhere…
Can any of you guys stick to the O p’s question
That is only one of the many ways that can be done.
The undersink outlet is unsafe due to its horizontal position. Recommend installing on the rear or side cabinet vertical surface to reduce possible water entry.
They would have to cut a large hole in the countertop to get the top of the island vent above the flood level of the sink The top of the island vent has to be installed as close as possible to the bottom of the countertop.
So where is the vent in this configuration?
Marcel has posted the correct configuration.
I thought you were talking about them dishwasher loop, lol.
I agree. The receptacle is code complaint unless you can argue that the GFCI is not readily accessible. In that case you could move the GFCI protection and use regular receptacles face up. Standard receptacles are permitted to be face up in surfaces other than countertops and floors. The bottom of a cabinet is neither.
