Outside backyard of this house I inspected had a makeshift pole, holding up some cable wire that went from the alley pole to the neighbor’s house. It appears to have be installed to hold the wire up in the air, as without it, it seems the cable would almost droop down to the ground. This can’t be legal, is it?
Buyer is concerned that her children playing can climb and/or knock over pole. Look at pic…
Agree as just above the house you can see the real service line coming to the home. Connects on the poll at the insulator or crimped on to the main. We have the same arrangement here as all the CATV and Phone attached is way bellow the power lines.
Yes, it is cable. So…should I call it out since it is in her yard? Is it a safety issue? Or a property dispute? If property dispute, I suppose I shouldn’t get involved.
Around here a simple phone call to the cable company would get it fixed. You may want to put it in your report that without the pole the cable can get damaged. Recommend the cable company be contacted to rectify.
