This essay is on XRF (X-ray fluorescence) which is a very accurate and reliable instrumentation-based method for quantitative analysis of chemical elements. The handheld XRF tool could be used as a preliminary method for detecting problem or Chinese drywall to Lead Paint. However this tool or method should not be relied upon as a complete test method. The device will measure levels of Strontium used as a dryer instead of lead paint or is contained in natural gypsum. Strontium is alkali earth element and Strontium sulfide is a stable compound that is insoluble in water requiring interaction with an acid to create hydrogen sulfide gas. Since drywall maintains a neutral-to-alkaline pH, it is difficult to calculate how the acid reaction will occur with the mere presence of humidity in the air. The alkaline pH makes the generation of hydrogen sulfide gas from strontium sulfide even less likely. Corrosive gas by products are the issue with Chinese drywall and it is not entirely clear that Strontium is the cause as drywall with low levels of Strontium have also produced corrosive gas but rather appears as a ride along marker. The presence of elemental sulfur was determined not to be a 100%-reliable indicator of problem drywall also. Seems determination of the cause is not conclusively indicated, I guess we’ll all stay tuned with Building Envelope Science Institute (BESI) for more information but an XRF Tool can provide some initial indication only.
The hot water tank should be checked for suitable drafting. This should reach proper drafting with in 60 seconds of firing. A hole should be drilled in the hood before the flue begins.Ensure you reset the hot water tank temp back to original temp.
Air infiltration comes from many sources during a blower door test. Use a smoke pin at baseboards, trim around fireplaces, windows and trim, any ceiling penetrations such as recessed light, attic hatches and ceiling fans. Also look for exterior defects such as rotted wood and cantilevered windows.
good post
mobdro for pc
download mobdro
mobdro on firestick
http://www.bigoliveforpcfreedownload.com/
http://www.mobdroforpcfreedownload.com/
http://www.mxplayerforpcfreedownload.com/
https://mobdroforpcfreedownload.wordpress.com/
thanks admin
great online Tv app for your windows PC
https://www.mobdroforpcdownload.com/
https://www.mobdroforpcdownload.com/mobdro-for-iphone-ipad-ios-apple-mac-free-download/
https://www.mobdroforpcdownload.com/mobdro-for-kodi-2017-addon-xbmc-install-guide/
https://www.mobdroforpcdownload.com/mobdro-on-firestick-tv-2017-install-guide/
https://allinoneseoo.wordpress.com/
http://allinoneseoo.weebly.com/
https://allinoneseoo.tumblr.com/
http://www.psiphonforpcwindows.com/
http://www.xenderforpcappdownload.com/
http://www.zapyaforpcfreedownload.com/
http://www.xenderforpcfreedownload.com/
A great tool for an inspector to have during a negative pressure test is an infrared camera. During a blower door test negative pressure is created in the conditioned space. Using an infrared camera will show where cold air is leaking into the house. It will be recommended that these areas be sealed up.
A home inspector should never do an energy audit for a client until he or she has completed a BPI course and is fully certified and qualified to do so. Doing so without proper certifications can leave you open to legal action.
In the attached photo there is a air leak on the top corner of the wall. Air leaks cause a large amount of heat loss and creates large amount of moisture penetration. Please refer to a building envelope expert. The leak should be sealed; or the energy bill will be higher and future moisture problems could occur.
Mortar Joints. There are 9 types of common mortar joints.
They are called: “V”, Beaded, Concave, Extruded, flush, grapevine, raked, struck, and weathered.
Not all of the joints are recommended in humid climates. Weathered mortar joints are considered to be the best type because it helps shed water from the joint. Other joints can be problematical in the long run because there could be water pooling in and around the joint.
Water penetration in the joint can be detrimental to your building envelope and exterior cladding systems.
Here is a picture of my hot water heater vent pipe. It is constructed with single walled vent pipe. It can be recommended that dryer lint be removed from the top of the unit as it is flammable. Connection should be better secured and sealed at thimble fire stop.
After studying the provided picture of air leakage at the home envelope, I seem as the caulking or sealant is an important part of the home build. Most use caulking as a cosmetic filler but it can help to create and maintain the home envelope.
A blower door is utilized in a home energy audit in order to create negative air pressure inside the home. The negative pressure will cause outside air to be drawn into the building through any gaps in the building envelope. Air infiltration can be detected with the use of smoke pencils and thermal imaging.
Factory built fireplaces, also known as zero clearance fireplaces are used approximately 75% of the time when a fireplace is to be installed. While masonry fireplaces are built onsite and are labour intensive, a factory built unit can be installed in a day.
The blower door test is a special tool design to help ensure that home is air sealed and efficient, and to help prevent the uncontrolled leaks in the home. There are many energy efficient incentive programs that require a blower door test.
In this image the inspector is checking for carbon monoxide back drafting from the hot water heater vent hood. If this appliance does not properly vent the poisonous carbon monoxide it can potentially kill the home inhabitants. This is the most dangerous component in the home.
I read the article conserve energy and save money. Some people are doing this to be more environmentally friendly but I think more are doing it to save their hard earned money. This article will greatly help the home owner accomplish both.
Anti-tip device is our crucial for safety at all ranges. An inspector should verify that is installed properly by keeping it forward. There were 143 incidents occurred between 1980 and 2006. If no anti-tip bracket is detected, inspectors should recommend that one be installed.
I found an image depicting multiple air flow patterns in a home. Wind Effect, Stack Effect, Combustion and Ventilation Effect. Understanding the changes of air flow through various conditions; will help better understand best practices for energy efficiency in changing environments.
Natural gas furnace flame
A natural gas flame should be blue, which indicates proper combustion. Long streaks of yellow or orange through the flame means the furnace needs adjustment or cleaning by a professional service technician.
Colors other than blue indicate insufficient combustion of the gas, which also increases the amount of carbon monoxide (CO) produced.
If the flame pattern is irregular or wavering, it may be time to call a service technician for further evaluation.
Perhaps you may wish to have a service contract with a heating and air conditioning company that checks your complete system annually.
