Pics we love to see
Originally Posted By: jremas
New construction inspection…hmmmmmmm…
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
570-362-1598
27 views and no comments on these 2 violations. Is everyone waiting for O’Connor & Tedesco to post? come on folks!
Jeff Remas
570-362-1598
Originally Posted By: Guest
Wiring way too close to nailing surface and no protection, wiring out of box too short.
Originally Posted By: wpedley
Hi Jeff
Pic#1
Way to close to nailing surface for drywall unless you
install a no-nailing plate.....but most sparkys I know
will go up through the plates and come down through
to the other wall.
Pic#2
A standard recpt. installation device/hanger should have been installed between the ceiling joists with a deeper box and more wire.But..... I also see this all the time...this by any chance wouldn't be in the Hideout
would it!!!!????? ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif) ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
BPedley
Inspecting for the unexpected
No, not the Hideout, it is in Albrightsville
So far so good...
Jeff Remas
570-362-1598
Originally Posted By: kpapp
The first pic need a nail plate…not sure why the foam fill though…could be a local code thing…
The second pic...wire way too short, no ground screw, only 2 screws of unknown length on this pancake supporting it...might be used for paddle fan making this too weak...Cannot tell if that is a grommet where the wire comes thru the box or puddy...
Ken
Do I win???? ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
_______________________________________
If you dont have time to do it right the first time, When will you have the time to go back and fix it?
Pic #1 p-plate needed.
Pic #2 wires not 6" long and metal box needs to be grounded.
Mike P.
Originally Posted By: kleonard
walk through is it?
Quote:
300.14 Length of Free Conductors at Outlets, Junctions, and Switch Points.
At least 150 mm (6 in.) of free conductor, measured from the point in the box where it emerges from its raceway or cable sheath, shall be left at each outlet, junction, and switch point for splices or the connection of luminaires (fixtures) or devices.
Where the opening to an outlet, junction, or switch point is less than 200 mm (8 in.) in any dimension, each conductor shall be long enough to extend at least 75 mm (3 in.) outside the opening.
Exception: Conductors that are not spliced or terminated at the outlet, junction, or switch point shall not be required to comply with 300.14.
Courtesy: www.nfpa.org
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
I’m no electrician…but i think maybe 14/2 wire for bath???
BPedley
gREAT Job:
1) METAL PLATE NEEDED
2) NOT ENOUGH WIRE HANGING OUT
THEM THERE ARE BASIC TERMS
No it is not a final. I don't see sheetrock yet.
Easy ones huh?
Jeff Remas
570-362-1598
I always thought it was curious that the IRC allows drilling within 5/8" of a stud edge, but there is no mention of protecting wires or that the electrical section/code would require protection plates for anything less than 1-1/4" edge distance … icon_eek.gif
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: Ed Griffin
I agree with everything stated, but have one question about the foam.
I am sure some people put the foam to prevent fire from traveling through, but I recently saw a little demonstration of how flammable some of such foams are. Could that be a problem?
