Originally Posted By: phinsperger This post was automatically imported from our archived forum.
If the beam were an engineered I beam you can’t cut the flanged PERIOD. But with a glulam solid beam I would think that you could notch as shown if the beam were oversized to begin with. I don’t know what the span here was but if the builder had a larger piece from another job and the remaining depth from top of the beam to the top of the notch were at least the depth called for I think thats ok. stupid to do because of the discussions it raises but ok to do.
Originally Posted By: jremas This post was automatically imported from our archived forum.
Engineered laminate beams cannot be notched without a letter of approval from the engineer specific to this house. Looks like the concrete guys screwed up and the framer took the short cut.
As far as the first picture, I am suprised no one caught on... The exhaust is to be vented to the outside, preferably through the roof and the duct work should be insulated in the unconditioned attic space. Placing the end of the duct in the soffit space is unacceptable. Remember the soffit is an INLET so it all comes right back into the attic to cause moisture problems.
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
Originally Posted By: Guest This post was automatically imported from our archived forum.
Jeff,
I agree that it’s very bad practice to vent the bath fan like that. But it’s allowed. I’m assuming that the vent goes through the soffit.
It’s in a bad spot over the window and the hose is crushed, but everything that I’ve read says it allowed to vent through the soffit. I’ll email a pic a to anyone that wants to resize it to post here showing what happens when you vent a bath fan like this in a cold climate.
Originally Posted By: dbroad This post was automatically imported from our archived forum.
I dident like the wire kinking the hose. However I have one that looks just like that one in my house and it is ran to a pipe that goes up to vent on the outside. Couldn’t see the end.
