Originally Posted By: Michael D Thomas
Can someone give me a description of the difference between a pilaster and a buttress used to reinforce a foundation wall? - Thanks.
Originally Posted By: staylor
Originally Posted By: dvalley
David Valley
MAB Member
http://www.masscertified.com
| staylor wrote: |
| A pilaster is a column built within a wall and projects out past the wall plane. It is designed to carry a load from above- not to strengthen the wall against lateral loads.
A buttress is typically an exterior pier of masonry, ofter sloped, and used to strengthen or support a wall or prevent movement from lateral loads. |
David Valley
MAB Member
| staylor wrote: |
| A pilaster is a column built within a wall and projects out past the wall plane. It is designed to carry a load from above- not to strengthen the wall against lateral loads. |
| Michael D Thomas wrote: |
| This is what's confusing me. The illustrations on this site show a plaister used to control lateral movement. |
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
