No issues running water at any fixtures as far as drain goes but wondering if I should have paid more attention for a gurgle after looking at my roof still shots off the video I took.
No access due to it being 4 floors and the top floor tenant has a private deck access above the porch in the rear.
I used my 30 foot pole at full length for the attached picture.
The kitchen at my 2nd floor unit is in front and about 15 feet towards my position.(off that chimney)
The only plumbing vent penetration I see is at rear (close) and above what would be the master bedroom bathroom.
So all plumbing is on the right and the same side as that fireplace chimney you can see which is the front living room of the unit.
Typical open concept with kitchen overlooking the Living room .
My question is shouldn’t there be a second vent stack near the front ?
Notice in my second picture under the sink the drywall was removed and their is no island vent.
(no idea why drywall was removed) split block construction however).
OK what would you say if anything in the report.
I am stumped.
Drywall was probably removed to add the insulation to the exterior wall.
Were you able to tell the diameter of the single vent stack? I would think it needed to be 3" minimum (possibly 4") for the entire vertical run to handle the demand of all the units combined. Pipe diameter will assist in determining the total horizontal run from the fixtures to the stack.
Bob, Looks like they installed a vent loop under the cabinet and everything seems to be in order (very limited view). This loop allows the sink to act as venting for the other fixtures (kinda like an AAV). I would probably let it go with a comment advising if problems in the future that repairs to the system may be needed.
I was on a roof once and all of a sudden the hair on the back of my neck stood up took a minute to understand there were NO plumbing vents thru the roof at least ya had one.:shock:
