polybutylene?
Originally Posted By: sseymore
http://www.nachi.org/bbsystem/usrimages/I/IMG_1275.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_1277.JPG ]
I just inspected a home that was built in the 1930s. All of the home was plumbed with galvanized and iron drains. But the bunk house was repiped with what appears to be polybutylene? I need some help. Is this pipe polybutylene? Thanks for your help, Sean
Originally Posted By: jhagarty
Appears to be PB2110
http://www.polybutylene.com/poly.html
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: Jay Moge
is that a threaded fitting on the TPR. and is the manual release pulled open???seems fishy. icon_cool.gif
Originally Posted By: Steven Brewster
Do you have any pictures of the connectors such as 90’s, couplers etc.?
http://www.polybutylene.com/selling.html
Joseph Hagarty
[email protected]
Phone: 610-399-9864
Fax : 610-399-9865
Originally Posted By: bkelly2
Sean what are the markings on the pipe? PB2110?
http://www.pbpipe.com/index1.htm
"I used to be disgusted, Now I try to Be amused"-Elvis Costello
Originally Posted By: rcooke
I tell people it is not a case of will the polybutylene leak but a case of when will the polybutylene leak.
Recommend repair immediately.
I feel most people do not follow what is written in the report.
They just put it of till the future.
Did A home last January 30 .
Told him he needed a new roof immediately.
He did not do it as it did not leak .
I was wrong the roof did not leak till September .
Now he has to put in a lot of new ceiling as well as new shingles.
Roy Cooke Sr.
http://Royshomeinspection.com
Originally Posted By: pdickerson
Yes, it is PB.
Make sure you call out the exposed NM-B, the missing grommet, the missing drain pan, and the missing straps (the straps may not be required in your area). Also check the age of the unit. It looks old.
Is that a cord cap on the end of the NM-B??? If so, it is definitely wrong.
Originally Posted By: whandley
Is PB acceptable at the wall penetration. In California I always find copper in use at the wall extrusions to the various plumbing fixtures. Without an attic, sometimes its difficult to know if PB is present, (Inaccessible). icon_idea.gif
on the pipes it says vangaurd plastics, potable tubing i’m pretty sure it’s polybutalene
