Interesting story out of Tampa, FL. I haven’t seen one in person for a few years.
Someone drained their inground pool, and hydrostatic pressure popped it out of the ground. Homeowner’s insurance won’t pay (don’t blame them) to fix the damages.
Yep, happens all the time when they don’t check the water table first. With a water table depth of a few feet, the empty pool turns into a concrete boat (which does float).
The water table is about 600 feet in Phoenix—:lol:, we drain our pools about every three years, or I do at least, you cannot balance the chemicals any longer.
Hey Dale we had that problem this year with chemicals. But main reason it was drained was to recoat it with plaster. I’m president of our HOA and few had concern about floating pool. I said we usually don’t have that problem here in GA but have seen it in FL!
I don’t know if they still do it, but, there used to be a copper plug that fits in a hole that was drilled in the pool. You have to chip out the marcite to get it out. That way if the water table comes up, it just fills the pool. I remember they guy using a metal detector to find ours.
I didn’t look at the article, but I know of a neighborhood in Coral Springs, where a bunch of pools popped when they were being refinished. On the one I inspected, they tried to make up the difference with thick pavers, unfortunately, the crack all the way around the pool about two feet from the floor, gave the game away.
llosciale
(Lawrence Losciale, HI 83, CBC022116, CPC0573)
12
All pools built in areas of a POSSIBLE high water table should have a dewatering system like the one John referred to. For most concrete pools it requires only about a 40" difference in the water level from inside to outside to cause them to pop or crack. The copper plug that was referred to by Eric is rarely if ever used any more, instead we use a “hydrostatic relief” valve. Basically a check valve typically installed in the main drain. Many pool contractors skip the hydro relief due to their tendency to leak, not the best plan. My pool construction company has to actually buy “pool pop” insurance in addition to our GL and there are damn few companies that sell it.
