system
(system)
June 30, 2004, 12:00am
Originally Posted By: Larry Urban This post was automatically imported from our archived forum.
1.Gravity flow furnace-what is not needed? Blower?
2.From conventional to high effiency-What might you have two of?
3.To inspect a gas system, you must be what? Approved by source or use approved procedures?
4.What size vent duct for a 1 ton ac unit? 6"?
5.Racking wall- What causes it?
6.Light on ceiling fan flickers- what causes it-bulb or cut wire?
7.Most common fault with evap. cooler?
8.3/12 pitch roof- what type of shingle? asphalt
9.How many switches on panel do you need to shut down system?
10.Attic ventilation- is it 1/300 or 1/500?
11.gfci tester vs. amprobe- which do you use to test receptacle?
12.incondescent light in room with no fixture- how do you report it? grand fathering or in need of repair?
13.Vent pipe going thru roof- how big can it be?
If your have answers to any or all of the questions please write them down before 6-1-2004
system
(system)
2
Originally Posted By: Nick Gromicko This post was automatically imported from our archived forum.
Staff member Lia Babitch is finishing our new State Exam Primer which includes over 1300 questions found on State home inspection examinations like the Texas TREC exam you mention. It includes a correct answer key as well. It is even designed to feel like a state exam so you get real practice, only it reveals the correct answer upon request.
We are about to release it any day now. It is password protected for members-only. We are making sure that all our NACHI members in states that require passing a state exam... pass... with flying colors.
-- Nick Gromicko
Founder
dues=79cents/day.
I much prefer email to private messages.
system
(system)
3
Originally Posted By: dcarroll This post was automatically imported from our archived forum.
Sorry, I don’t think we can answer these before 6/1/04.
system
(system)
4
This is the best I can do with these questions. If I’m wrong please chime in.
1, blower
2, heat exchangers
3, ?
4, just a guess 10 inches
5, ?
6, Bulb
7, Doesn’t work with high humidity.
8, asphalt
9, 6
10, 1/500
11, GFCI
12, In need of repair
13, ?
system
(system)
5
Answer to number ten is 1/300
system
(system)
6
Originally Posted By: dbowers This post was automatically imported from our archived forum.
Daniel -
Actually #10 is only 1/300 if certain conditions exist. The basic number is 1/150.
system
(system)
7
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
5. not properly braced by let in 1x4 bracing or plywood sheeting.
–Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
July 7, 2004, 12:00am
8
We’re still adding in a couple hundred more questions and answers but we have almost 1300 done.
This is a new licensing exam prep tool.
http://www.nachi.org/qa.htm
Nick
-- Nick Gromicko
Founder
dues=79cents/day.
