Welcome To Questions of The Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
High-efficiency gas furnaces installed in old duct work tend to -
a) Lose efficiency
b) Have higher maintenance requirements
c) Have excess temperature rise across the heat exchanger
d) Have shorter life spans
e) All of the above -
Which of the following is not a normal installation on a pulse high-efficiency furnace?
a) Vibration damping in the duct connections
b) Rubber isolation mounts on the furnace
c) Flexible gas connector
d) Exterior duct insulation
e) A tailpipe -
Common condensate problems on high-efficiency furnaces include all of the following except-
a) Blocked condensate lines
b) Leaking condensate lines
c) No automatic air vent in condensate lines
d) Poor discharge location
e) Missing or clogged neutralizer -
Which of these has the greatest heat delivery per length (e.g. a two foot long unit)
a) Radiators
b) Convectors
c) Baseboards
d) Radiant piping
e) Distribution piping -
The anticipator on a thermostat is used to -
a) Start the furnace in anticipation of a temperature drop
b) Stop the furnace early to reduce overheating of the house
c) Control current flow to the furnace transformer
d) Control current flow to the furnace gas valve
e) Prevent the air conditioner from cycling if it is too cold outside
Bonus riddle:
Which word in the dictionary is always spelt incorrectly?
