I’m curious to see what other inspectors are charging for commercial roof infrared thermal scans. Are you charging by the square foot, hour, or quoting each job individually? For example 20+ year old 53,000 square foot modified bitumen flat roof system. If charging by the square foot or by the hour, what rates are you guys charging? Thanks.
Kenneth,
I believe most Thermographers charge by square footage, but put a minumum fee on the project.
For example:
I charge 2,500 for an ITI Roof Survey up to 50,000 square feet. Any roof larger than 50,000 square feet, would be .05 p/square foot.
I know there are others that charge less, but you have to remember that these surveys are conducted at night and require a least two people.
You could charge anywhere from .03 to .10 p/square foot, which really depends on your particular market. I’ve had a few recent ITI Roof Surveys and none of my clients flinched at my pricing.
Hope this is helpful…
Kevin
ditto!
What is this service that you call a commercial roof infrared thermal scan?
Is this a part of a whole roof inspection?
It is a specific Infrared application to detect latent moisture in an insulated or built-up roof.
http://www.infrared-diagnostics.com/itiroof.php
http://www.flirthermography.com/media/roofing_brochure.pdf
http://www.flirthermography.com/media/roofinspections.pdf
http://www.flirthermography.com/media/023barker.pdf
Kevin
Thanks for your help Kevin! Your new commercial ITI website looks great!
